Question about Palit Microsystems PalitDaytona GeForce2 MX400 (64 MB) PCI Graphic Card
MY MONITOR NOt WORK WHEN I USE MY NVIDIA PCI CARD ?
My porblem is that my pci card is new and worked fine for many weeks
but now when turn on my computer the monitor dont come on and the monitor led light keep blinking but nothin happens after that what is the problem plz help me i dont want to buy a new card because i dont have cash for it these days.
  • 5,568 Answers
Most monitors made in the last decade will put some kind of warning on the screen if they are not receiving a video signal so if you get no on-screen display at all, regardless of whether the system is on or off, you probably have a monitor failure.
Try to borrow a monitor temporarily so you can try the following:
- If the borrowed monitor also shows nothing; your card has failed. - If it does give you a normal display, go to the Control Panel, open theSystem folder, select Hardware, then Device Manager. If there is no 'X' next to the Display adaptors, expand that entry and delete the monitor shown. Then go to the Monitor entry, if there is no 'X' next to the entry, expand it and delete the monitor listing.
- Power down the system.  - Disconnect the borrowed monitor and reconnect yours.  Make sure the standby or power LED is on your monitor. - Restart the system
If Windows has simply trashed the driver, it should 'find' a 'new device' and install some kind of basic driver.
If nothing has worked; then the card is dead. If it worked with the borrowed monitor, then your monitor is dead.
BTW; if you really have had the card only 'weeks,' it will still be covered by the manufacturer's warranty; most Palit cards I saw when searching had at least a one year warranty.
Posted on Nov 24, 2008
MY HP500B MT wont wake up
what card? full model numbers only work/.
is it a used card? or new?
did you leave off the yellow wire connector? if present.
quadra tells the helper ZERO. google that name , endless cards.
all very different..
the card is bad (test it in other pc?)
or the wrong card
or the wrong slot used.
the extra power cable , ignored, oops that is super bad. error.
that MOBO has 4 slots ,which one
buttom up
PCI.
pci-e x1
pci-e x1
pci--e X16
what?; and tell full spec on card, a photo works or link to same.
why post lacking full card spec.>>>??
vast video cards exist. powerful ones have aux power cables.
the card has manual read it yets
top end card tells you to change the PSU, for AMPS
if you dont, do as it tells you ,there IS NO HOPE ever.
here is one, that sucks, power
Maximum power consumption: 250 W (just the card !!!)
this card has the 8 pin yellow wire aux connector if not fitted, it fails
if you dont have 500w PSU or larger it a doomed thing,
Sep 25, 2017 | HP 500B MT PDC27 3GB 500GBDVDR W7P SBY...
My pci Express is8500Gt.my desktop is celoren D,1.80Gz.250HDD,ram 1gb. last week i install it and play nsf Carbon,everything is allright.2 days after when i go to turn on my Desktop then i see my monitor...
If your graphics card works on another pc but not on yours then you should try another graphics card on your pc. If it also doesn't work it means it's a problem with your motherboard.
May 24, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
Respected Sir, I installed an nvidia 8400gs graphic card a year ago..........it works fine ....then two weeks ago i dusted up my cpu...........i inserted the graphic card then the computer...
it is because your nvidia card was broken, it makes the windows won't boot up, try to clean up your nvdia card (yellow circuit which will connect to the pci of the mother board) using a pencil eraser
i suggest you to change your nvdia card with a new one
May 14, 2011 | Dell Inspiron 6000 Notebook
The second PCI-e slot doesn't seem to work.
Did you check your BIOS to be sure that both PCI-E slots are enabled? If so, then did your check the documentation that came with your video cards to see if there's any setting your have to make\change in order to run the cards in SLI? The User's Manual for the motherboard may tell you if BIOS settings have to be change for running in SLI.
Mar 24, 2010 | Computers & Internet
No color Red, Dell XPS 400, NVIDIA GeForce 7300 LE video card
Mike,
I would recommend for you to try different monitor, so that you can isolate the problem.
If same problem occur, try to plug in your video card into another PCI slot in your computer. Cleaning the gold fingers of the video card with a clean cotton cloth might help.
Use a blower to remove some dust on the PCI slot.
Or try inserting the video card in another computer. If you get the same problem on another computer, you need to replace the card.
Mar 07, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
Nvidia Geforce 8400 GS (PCI)- easy installation is not so easy.
What sys prog are you running, rem not all progs are compatible. ie Vista? Pain the u no were!!
Nov 09, 2009 | Computers & Internet
A8N-SLI Premium & NVIDIA GeForce 7800GT
Sounds like your getting conflicts with running two different card drivers. I've never heard of running a PCI and a PCIe card at the same time.
Jan 09, 2009 | ASUS GeForce 7800GT, (256 MB) PCI Express...
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
NVIDIA PCI Card Issue at system boot
re-seat the graphics card, check the temperature, if overclocked try to put it at stock or RMA the card might be faulty
Mar 17, 2008 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
Palit Microsystems PalitDaytona GeForce2 MX400 (64 MB) PCI Graphic Card Logo
97 people viewed this question
Top Palit Microsystems Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Are you a Palit Microsystems Computer and Internet Expert? Answer questions, earn points and help others
