Ok. I got this sansa for christmas.
And i accidently delete every things in the sansa.
I can't listen to music no more or even the Channel thingy.
It does show all the song when i connect it into the computer,but it doesn't show in my sansa.
What should i do???
Please help!!!!!!!
"Connect your player, of course. Go to "My Computer" > "Sansa e260".
There are hidden files. To unhide go to "Tools" (located on the menu
bar) > "Folder Options..." > hit the "View" tab > select "Show
hidden files and folders". You will see more folders to appear in a
faded color. Click on the "MUSIC" folder. Click on the artist, then
album then select the song, right click and down to delete." --Yahoo Answers
Ok, plug it in your computer, open "My Computer," open up your Sansa, open up the file named "Music," select all the files, right click them and click delete. Now go to the Recycling Bin and delete all the music files that were on your Sansa. Sometimes the Sansa doesn't realize that files are gone until you delete them from the Recycling Bin, crazy I know, but it's true.
Hope it helps!
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
There is a problem with the device firmware itself..you can try to reset the player by holding the power button down for 15-20 seconds or until it resets....the latest firmware for the e280 resolved much of the freezing issues....also there are two modes for you to use the e280 the msc and mtp.....try deleting in mtp mode....if that doenst solve it...just go to the sandisk site to get a firmware upgrade done...and that would solve the proplems..
Using msc mode, use my computer and right click on the drive corresponding to the mp3 player, and select format. That should clean up anything that's causing problems.
As far as the player refreshing every time it starts, this is NORMAL, and it WILL take extra time since you have an additional memory card to scan.
Ok, I have a Sansa e250 2.0 BG. I have an extra memory card but w/e thats not part of the problem. So, when I downloaded music, I accidently put more music on the Sansa memory and it made it too full. So now it has to do a system restart everytime I turn it on. Which is really annoying. And then I tried to delete some music so It would stop doing that and I could update it, But it shows up on my computer as there being no music. So theres nothing to delete! But it says the memory is full! HELP!!!!
I have a smaller Sansa, and I have had to reconnect it to my computer, go to the files on it, and delete. I believe I had to right click to get the delete option. There is no delete capability that I know of on the Sansa. I found out just by trial and error, as I have not printed out the manual. I had saved all Christmas music for my dance class party, then needed to delete it. Hope this helps.
It might have reformatted the songs by accident. Just try to redounload the songs you want and dont download the ones that you wanted to delete in the first place. This happens a lot with Sandisk e250 mP3 players
