Question about Sub-Zero 601R
Sub-zero 601 fridge won't get below 42 degrees
Vacuum condenser isn't flashingwhen I press the colder button, it flashes 34 degrees and then goes back to 42
  • summach1 Dec 04, 2008
    We have the same problem on our 601R.  The cooling element that is hidden behind back wall panel has a frozen section on top left corner.
  • 56 Answers
You both sound like you need a qualified factory repairman out there. If there is a blockk of ice on the back wall you have a low charge in the refrigerant system. It is most likely the evaporator or cooling element as you call it which has a five year parts and labor warranty, then parts only for years 6-12. Here is the link to the factory locator site. or call 800-222-7820.
Posted on Dec 06, 2008
My sub-zero 642 will not get colder in the freezer than about 9 degrees and the fridge won't get colder than about 45 degrees. I turned off the breaker and vacuumed the coils, but still no change. ...
The Sub Zero 642 uses independent refrigeration meaning the freezer and refrigerator each has their own system. Best to have an "Authorized Factory Service Company" check it out.
Jun 08, 2011 | Refrigerators
Vacuum condensor light flashing and the refrigerator won't get colder than 51 degrees.
The light is indication a problem with the condenser coils being covered with dust/dirt and cannot dissipate the heat energy absorbed by the system in the evaporator coils (freezer). Or the condenser fan is not running. Clean the condensor and/or check the fan.
Nov 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
601R sub zero vacuum condenser notice
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Jun 27, 2009 | Sub-Zero 601R
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
423 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
