Question about Philips 19PS35S 19" TV
I want to retune Philips 32PW9576 / 05E
I don't know how to manually search & store channels for my Philips 32PW9576 / 05E television set.
Can you advise?
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
I have Philips DVDR7260H recorder where the guide plus system will not set up. I have done as insructed on automatic and with manual setting with host channel set to bid up tv channel 23with no lck . C...
Firstly, my DVDR7260 (so I guess yours too) can only use analogue channel updates so it should be set to ITV, that is channel 03 (if you have usual analogue channels tuned). BUT by now that suggestion is redundant as Guide Plus updates have been stopped since 1st Jan 2011 as part of the Digital switch-over. Nice one! If anyone knows how to invoke the Freeview EPG on the DVDR7260, that may be the one thing to keep it out of the bin.
Dec 15, 2010 | Televison & Video
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Someone tried changing channel manually. Now I get a message that says "run auto channel search' but I don't know how to do this, please advise
    you have to be on the Cable/Antenna Input. Then you can access the menu option to auto search for you channels again.
    Mar 21, 2010 | Insignia 37" LCD Flat-Panel HDTV
    Programming channels
    The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
    Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
    No colour, contrast or volume memory. Channel memory OK, have fitted new battery.
    Sounds like the eprom! I don,t have that manual in front of me but if it has a 8 pin eprom, try this, remove it and see if your settings are available and operational,( the ones in question) if they are then it is defective.
    Apr 28, 2009 | Televison & Video
    How do i tune my philips 3590H philips dvd recorder into digital
    The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
    Info related to your specific problem is as follows...
    Setting your TV channel
    programmes
    Before the recorder can start recording
    the TV channel programmes, you need to
    search for the available TV channels and
    store them in the recorder.
    Note: Make sure you have successfully
    made all the required connections to the
    recorder, the TV and Satellite Receiver/
    Cable Box (if any) and switched them on.
    Tuner settings can only be changed
    when there is no disc in the disc tray.
    A Press SYSTEM-MENU on the remote
    control.
    �� The system menu appears on the TV.
    B Use ���� keys to highlight
    { System Menu - Channel Setup }
    and press ��.
    Modify Channel Information
    Sort Channels
    Channel Search
    Edit
    Sort
    C Use ���� keys to highlight { Channel
    Search } and press OK.
    �� The automatic TV channel search
    starts. This process may take several
    minutes. Once complete, the total
    number of channels found appears on the
    TV.
    Automatically scan all the receivable analogue local TV
    channels and store these channels on the recorder.
    �� Use ���� keys to highlight { Channel Search } and press OK.
    �� The automatic TV channel search starts. This process may take
    several minutes. Once complete, the total number of channels found
    and stored appears on the TV.
    Modify Channel Adjust a stored TV channel to your preference, improve the
    Information reception and the sound quality of that TV channel.
    1) Use ���� keys to highlight { Modify Channel Information } and
    press OK.
    �� The channel menu appears.
    2) Use ���� keys to select one of the options.
    { Name } – You can use the numeric keypad 0-9 to select
    the channel preset number which you wish to
    change.
    – Use ����keys to change alphabet/ number and
    use ���� keys to select different entry fi elds, then
    press OK to confi rm.
    { Scan Mode } – Select TV channel search mode based on
    channel allocation or frequency.
    – Use ���� keys to select { Frequency },
    { Channel } or { S-Channel } (Special Channel),
    then press OK to confi rm.
    { Frequency } – Shows the frequency of the current TV
    channel.
    – If required, use ���� keys to start the automatic
    frequency search and press OK to confi rm.
    { TV System } – Set the TV system that produces the least
    distortion of picture and sound.
    – Use ���� keys to select a suitable sound mode,
    then press OK to confi rm. (See chapter “TV
    System Guide” at the back of this manual for
    more information).
    { NICAM } – Turn on or off the digital sound transmission
    system which improves the sound quality of the
    TV channel.
    – Use ���� keys to select { On } or { Off }, then
    Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
    Trouble finding PIN#
    Here is a link to download the manual, just click on the 'Start Download" button. The manual should tell you how to reset the code.
    http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=6d70389c9913c26b2d1d3a4d21a92dbc&q=Philips+37PF7320A
    Dec 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
    Set up an a Panasonic TZ-20L3Z
    Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
    Aug 19, 2007 | Toshiba 27A34 27" TV
    Philips 19PS35S 19" TV Logo
    265 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
