View and View Technologies VNV AquaView 9LS 19 in.CRT Conventional Monitor
Problem for View and View Technologies VNV AquaView 9LS 19 in.CRT...
Monitor problem: screen goes black, then comes in scrambled
By sawing14s on Dec 31, 2006
I've had an Aquaview 9LS View & View monitor for almost 4 years (I use Mac OS X 10.3.9). Since tonight (about 1.5 hours ago as I type this), my monitor has been going black (even though the screen is on), then the image comes back again, flickering. There's this weird small cranking noise coming from inside the monitor (which reminds me of a light bulb), and the signal looks scrambled, as if there's a loose cable, or a dim bulb, or something. I've checked all my connections (though I didn't unplug anything), and they all seem to be sturdy. If the screen goes completely black for more than 30 seconds, I just turn the monitor off, then back on, which solves the problem until it happens again (usually 30-60 minutes later). How long do these monitors usually last? Is it possible that I might need a replacement?
Solution #1
posted on Jan 02, 2007
Not Rated)
MicrowaveSvc
Rank: Guru
Rating: 89%, 5019 votes
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
One or more backlights may be going out, too.
Was this helpful?
Yes
No
Popular Solutions for View and View Technologies VNV
Questions and Unsolved Problems for View and View Technologies VNV
Do you recommend View and View Technologies VNV AquaView 9LS 19 in.CRT Conventional Monitor?
Answer
Answer
sva 2209 W model....should I have sound with this monitor?
Answer
When i turn on my computer my lgw2242t monitor say's analog and then goes black. However the blue... (More)
Answer
I have a tatung VS 14439 power supply with no output. Any usual culprits? It's out of a Bally game... (More)
Answer
hi! where can I get a power cord for a balance digital monitor # CM 2019? Thanks
Answer
Va912b first cuts on with mostly blank but with broken strips of lines from top to bottom and have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
