Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
Ice build up out side hitting fan
When temp drops below 32 ice builds up and fan blades outside hit ice.Is this unit supposed to drain all condensation out? Does this unit have drain holes?
Ge Model # AZ38H15DABM1
P/S repair man replaced motor last winter this winter doing same thing I can see ice in unit I put heat lamps under unit outside to help melt ice.
Please help!
  • emiller755 Nov 24, 2008
    Found problem drain valve not functioning properly
    Problem Solver:
  • 7 Answers
Pop out drain plug heat up pan with heat gun to melt ice
Posted on Dec 16, 2008
Ice builds up on top of evaporator and fan blade hits.I checked evaporator and there was no ice build up below this area. I thought it might be a defrost problem but coil is totally iced. I thawed it out...
This sounds like no defrost is happening. Frost is supposed to accumulate and then be heated and water runs off, routinely.
Check defrost timer and heating coil.
Mar 18, 2015 | Whirlpool WRF560SEY 30" French Door...
Clogged drain plug
Happens to me too. The drain freezes, freezer floor freezes and then ice starts building up to the point where it forms in the fan area and then the blades hit the fan and it gets very noisy. In my case, the container that is supposed to carry the defrosted water to the drain has a electric wire running underneath and twisting around the drain hole. I believe this wire is supposed to heat up and melt the ice to stop the drain hole from freezing. I believe the heating mechanism has failed in my case and suspect the same for you. Until fixed, this will continue to freeze up every so often. Search for your LG freezer drain heating element or parts.
Mar 13, 2014 | LG Refrigerators
Drain channel freezes
I had that ice build-up problem on a side-by-side GE. In the end, it turned out to be the defrost timer. After 20 years of use, it wasn't keeping the defrost cycle ON long enough to let all the water drain out. After replacing the timer, problem disappeared.
Mar 11, 2014 | GE GBS18HBM Bottom Freezer Refrigerator
Ice machine not dropping. Hit reset drops ice refills with water, but then it does not drop ice again unless you hit the reset RS2530
In case the ice is not getting ejected and seems to be stuck in the ice maker, the defect lies in the ejector mechanism. Since the ice maker cannot eject the ice, you need to put it to the manual shut off mode, so that ice maker doesn't continue to make more ice. In such a scenario, you will need to shut off the power to the freezer for carrying out the repair, so if you are not comfortable with handling electrical appliances, you could seek professional help.
Jun 25, 2011 | Samsung RS2534 Side by Side Refrigerator
The freezer motor starts whenever I close the freezer door. It is loud and sounds like something is hitting a fan.
The evaporator fan motor inside your fridge is constantly trying to keep the temperature you have set it to. when the fan is on it circulates the cold air from your freezer in to your fridge. if you hear a banging noise it is cause by the fan hitting a build up of ice. this can be caused by a clogged drain pan or tube, not allowing water build up to be drained, or you could also have a defrost heater issue in which case you would have a large build up of ice near your fan. you can access the fan motor by removing the two panels at the back of the freezer, once removed you will be able to see whether or not there is a ice build up.hope this helps you
Thanks.
Oct 11, 2009 | GE GSL25JFPBS Side by Side Refrigerator
HI mAYTAG gc20c7c3ev SIDE BY SIDE FRIDGE seems very loud lately - fan it seems . Is this a problem looming? can it be solved. It used to "charge up" and then wind down every so often - presumably to...
I would check to see if the fan blades are hitting something or if ice has built up around the area causing the sound to change.Based on your model number your fan should not be changing speeds. You'll need to remove the rear cover in the freezer to access it and you can also inspect the coils below the fan for ice build up which should be a light frosting but not a heavy buildup. Test the evaporator fan here. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 22, 2009 | Maytag MSD2656G Side by Side Refrigerator
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
306 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
