Omnibook 4150 password
Hi, I bought a second hand omnibook 4150 from e-bay, its hd wont boot and I cant access the bios to change boot to cd dr as I need a password the hash code is 05482 can you tell me the password from this? many thanks
  • 4,806 Answers
One Time, I forgot BIOS PASSWORD OMNIBOOK 4150XE2.
I had to find a way to clear the CMOS on my own.
(1) Remove the memory access panel.
(2) Remove the sticks of memory.
(3) I believe it is the top stick, but it may be the bottom. There are two solder points that stand out.
(4) With a small screwdriver or other tool, short these two contacts.
(5) Replace the memory and put the access panel back on.
Your CMOS should now be cleared. I have only done this on an XE2, but chances are there are similar ways on other HP laptops.
Make much attention... it can be dangerous.
If you want, try this solution, BUT YOUR RESPONSABILITY.
or
H.P. will provide a solution FREE OF CHARGE even though the laptop is out of warranty.....unbelievable I know !!!!
You have to try and give proof of purchase, very important, then a code is given which you enter in the bios. Then you contact H.P. with the resultant code and then your bios password will be unlocked........
regards
Posted on Nov 24, 2008
IS UNDOCK ENABLED OR DISABLED ?
1. From the Start menu, shut down, then restart the OmniBook.
2. When you see the HP logo, press F2 to enter the BIOS Setup utility.
3. Select the Security menu.
Under Password Required To, choose when the password will be required.
Boot. Requires a password when booting the OmniBook. This option enables the next
two options.
Resume. Requires a password when resuming from Suspend.
Undock. Requires a password when undocking the OmniBook.
See the Manual for more details.
two options.
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=31634&docId=emr_na-bpi04015&docLocale=en_US
Mar 04, 2015 | HP Omnibook 4150 14.1 in. Flat Panel LCD...
Tip
Problem: You do not have access to change the settings in BIOS? . Have bought a...
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Reported AMIbackdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW,BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enoxxo11nE
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
ToshibaToshiba
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•ACER/IBM BIOS
•AMI BIOS
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Toshiba
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Jan 29, 2010 | Computers & Internet
I have an Omni Book 500 That wont let me change the bios is there someway to get around that ?
I am guessing that you are attempting to use a non supervisor level password. There is usually a facility to set both a user (restricted function) password and a setup password (administrator rights access). You may need to reset the passwords within the bios setup.
Apr 10, 2014 | HEWLETT-PACKARD Omnibook 510...
Jumpers on c500 compaq presario laptop
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 28, 2013 | Compaq Presario M2000 Notebook
Laptop stopped booting
It is dead... give it a decent burial... win 98 is not functional anymore...
Jan 10, 2013 | HP Compaq Business Notebook NX9010
Cant get password to work on my Ferrari 1100 acer
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Dec 17, 2012 | Acer Ferrari 1100 Notebook
Bought used phone 8330 unable to access password keeper due to old password installedinjune 2008 it alowed me to install new password, but when I tried my new password ,it requested the old one first which...
When you boot up to the log in screen type in administrator as user if you cant log in
During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
May 04, 2011 | Computers & Internet
I have a toshiba 440cdt, cant remember password, it also wont boot from cd? i have held esc then f1 to get into bios and changed boot sequence to cd 1st, but still cant boot from cd or get through bios...
You might have to go to Toshiba support and get a BIOS Flash to update for your BIOS. Win XP is no longer supported, therefore you may need to go to Windows 10.
Feb 06, 2018 | Toshiba Satellite Pro 490CDT Notebook
Fogotten password
If it is the Windows password that was forgotten, you can google Offline NT Password Recovery & Registry Editor and use that to blank your password in order to gain access. The download is an ISO image that must be burned to a CD, then you boot your computer with this CD which runs a small dedicated linux kernel and text-based application that will allow you to change your passwords on the accounts or blank them. The change functionality does not always work correctly so you should just choose to blank the password instead.
MAKE SURE YOU READ ALL OF THE DOCUMENTATION SINCE MISTAKES WHILE USING THIS TOOL CAN RENDER YOUR SYSTEM INOPERABLE AND MAY REQUIRE REINSTALLING EVERYTHING.
May 30, 2009 | HP 80GB NOTEBOOK HARD DRIVE KIT FOR HP...
BIOS stops booting with two CD checks
1. Chek whether the time and date is correct
2. If No, change BIOS Battery, if Yes, No need to change the Battery
3. Install the latest Version BIOS (if the existing is the L8st, then reinstall)
4. Selct "Load Optimal Default" in BIOS and try to boot
Dec 15, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
271 people viewed this question
Alun Cox
David Payne
David Payne
