Question about GE Spacemaker JVM1640SJ Microwave Oven
Repair turntable for spacesaver XL1400
The turntable stopped turning. How can I repair that on my own?
  • GE Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Posted on Nov 25, 2008
Does the ge spacesaver xl1400 microwave have to mounted or can it just sit on a counter?
Theoretically JVM1400-series microwaves (XL1400 is a meaningless number they put on the ovens) can be used on a counter top, but it's really not safe because it has no feet, and it may slide and fall off the counter.
Also, it will probably not set level on a counter.
You can download GE owner's manuals and installation instructions here.
If you need mounting hardware or other parts, you can get them by by entering your full model number from the tag on the oven here.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacesaver PVM1870 microwave - the turntable has suddenly stopped turning. I've tried the "Turntable On/Off" button, but it did not help. What else can I try?
Perhaps the turntable motor has failed. Replace it as soon as possible as if you don't the food will not cook properly.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | General Electric PVM1870SMSS Microwave...
My GE Spacesaver XL1400 quit heating last night. everything seems to be wroking except no heat. Is there something I can check for an easy fix or should I just replace the microwave. thanks, dan
This is a fairly common problem. I have a tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat which explains the fix, where to go for parts and how to troubleshoot the unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous repair.
Mar 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable on our XL1400 stopped working. Is
the diskmotor is defect?
mesure the resistor of the motor with reduction under the plate the value must be bethween 60 and 100 Ohm.
if not the coil is burnd and you have to replace the motor.
Feb 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, This is Mike. My GE spacesaver xl1400 is shutting off as if it has lost AC power seconds after hitting the start button. The last couple of times it reset itself and now its dead. (power source is ok)....
-thermal cutout
-fan/fan motor
-transformer
-capacitor/diode
-circuit board, triac or magnetron
any of these could be the culprit
any of these can be tested
let me know if you need further instructions
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave table wont turn
either your turntable motor part# WB26X10037 G.E. is bad or the motors capacitor part# AP2026076 is defective they are both the same price
Oct 08, 2009 | GE JVM1440 Microwave Oven
The turntable in my GE XL1400 stopped turning. How do I reach the motor to clean or replace?
They MIGHT have a belt between the motor and the turntable drive wheel that may have gone bad, rather than the motor. The unit will have to be removed from the case to get to the innards.
Sep 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytewyteyu
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver turntable will not turn
my mocrowave turntable will not turn but it will heat up.
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
123 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
