Question about Metz 60CT-1 Flash
Flash doesn't fire properly at regular position
Hi, I've just bought a Metz 60CT-4. I was testing bouncing its head at several positions and I noticed that at normal position (90 degrees) it doesn't fire regularly. The pictures get too dark. When I bounce it for any side, the pictures come out right. I really appreciate any help.
    Champion:
    Scholar:
  • 216 Answers
Did you buy this used or new?
If used: neck has broken/shorted wires.
Try fires with the Test Button in A mode with hand blocking sensor and then without. Move head around.
If I can help.
atdlee@netzero.com
Posted on Dec 30, 2007
SOURCE:
Metz 60ct-1 manual
USE A REMOTE FLASH TRIGGER I USE IT ON MY 60CT FLASH ON 5D11
Apr 07, 2012 | Metz 60CT-1 Flash
I have a metz 60 ct 1 flash gun its not warking auto i think cr3jm trak was burnd i repace those part but still its not warking are there any problem
Sometimes the long slide switch (pcb switch) gets worn with metal particles rubbed onto tracks from the contacts. The switch then has partial shorts and only works on certain positions. The track looks black when this happens. Clean with alcohol and rub vigorously with toothbrush and swabs.
Jul 15, 2010 | Metz 60CT-1 Flash
Use of the mecablitz 60ct-4
Go to the website of metz: www.metz.de and choose english. Then go to their flash gun site, there is a manual available for this flash too. And most important of all: It's free!
Nov 16, 2009 | Metz Mecablitz 60CT4 TTL Flash
Metz Flash Power?
Hi Tom,
The battery is Metz Accu 60-38 4.5Ah at 6VDC
VRLA Battery 100 20 4010
Any Pb battery at 4.5Ah or higher will do.
Toy & Us sells some of them for kid cars.
eltroman
atdlee@netzero.com
Oct 10, 2008 | Metz Mecablitz 60CT4 TTL Flash
My 60CT-1 only fires at full power. Worked fine one day the next time I used the unit it would only fire full power each flash.
Is the top dial set on AUTO?
Is the sensor window clean or obstructed?
Checking both of these may solve your problem. Do you have a Manual for this flash? There are free pdf downloads on the I/Net.
Jun 16, 2008 | Metz 60CT-1 Flash
60ct4 metz flash head
Hi Canday, As the connections are OK, it is possible that a lead inside one of the wires is broken. You don't say if it powers up or not, so it is very difficult to give more specific advice or diagnosis. It is a professional unit, so I suggest you take it into a top camera shop for their advice. Good luch, John Hannah
Apr 05, 2007 | Metz 60CT-1 Flash
Can't fire properly at 90 degrees
Did you buy this used? Maybe the following problems: wires inside are loose or cold soldered. Flash tube has coated with film coating or flash head(inside)is dirty. Alexander atdlee@netzero.com
Jan 13, 2007 | Metz Mecablitz 60CT4 TTL Flash
Metz 60CT-1 Flash Logo
128 people viewed this question
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
