Question about Goodman GMS90703BXA Heater
Led flashes all the time heater won't start
Gds80703axbc downdraft furnance won' t heat
  • a_c_clevelan Nov 24, 2008
    i changed the hot and neutral at the furnance and the light went solid ,there must be a problem with the wiring in this house somewhere...thNks for your help
    ther must be a problem with the wiring in the house, the furnance worked before ,reversed the hot and neutral and it now works thanks for your help
Some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
Posted on Nov 25, 2008
Do you know if they purged the gas lines? Sometimes when the meters are changed air can build up in the gas line
Dec 07, 2012 | Heating & Cooling
How to make sure you Heat is working
A common problem with a furnance is the furnance will attempt to ignite, several times, you will notice that the house is not heating properly. You will hear the furnance come on and you will assume the heat is on, and the house will continue to be cool. You wiil check the furnance and you will hear it start up and the blower will come on, however a few seconds later after you have walked away the blower will shut down and there is no heat on at this time. You will again go check the furnance and after the furnance start and go through the cycle the furnance will shut down you will notice that the furnance has indeed shut down. This is the common problem of the flame sensor, you will have to remove the flame sensor, get a small piece of fine grade sand paper, and remove all the black colored carbon from the flame sensor until is is shinning bright, replace the flame sensor and attempt to start the furnance. You will notice that apatment or house have reach the set temperture, that the furnance has went through its cycle and the furnance will ignite and stay on continueously until the house obtain the preset temperture..
on Dec 13, 2009 | Heating & Cooling
Honeywell heat/cool thermostat keeps turning furnance on
This is not the thermostat, it is most likely the controller in the furnace.
Aug 10, 2012 | Honeywell Heat/Cool Thermostat
Furnance not starting
Try cleaning the flame sensor. Its the most common problem on todays furances. You should clean it with a fine grit sandpaper or emery cloth once a year.
Apr 11, 2009 | Heating & Cooling
No heat through vents
Does your condo have more than one thermostat? if so there are powered dampers that open and close to direct heat where it's being called for. You may have dampers stuck/inoperative.
Mar 22, 2009 | Omega Trane Furnace Draft Inducer Blower ...
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Goodman GMS90703BXA Heater Logo
139 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
