Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile side by side refrigerator
Thanks for the help and your suggestions helped me solve the problem. The coils were frozen over and I thawed them out and replaced the defrost heating elemant and thermostat. It works as good as new. Thanks again.
  • 1,122 Answers
Did you leave me a fixya rating?thanks-mike
Posted on Nov 25, 2008
I can not remove the ice bin of my Arctica 25.4 refrigerator. I know how, i
My guess is that it may be frozen in place. Have you removed the ice bin before? I would start by turning off the thermostat of your freezer, thawing it out and cleaning the heck out of it, it may solve your problem.
Sep 08, 2012 | GE Profile Arctica 25.4 Cubic Feet...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Our GE Profile has stopped Freezing. It does not make ice and many items have "thawed out" - including melted ice cream. Please help! We can't afford a new fridge. Thanks.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Nov 28, 2010 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile side by side refrigerator keeps going to express thaw mode and temp is way out of range. Any ideas on the problem?
Nov 24, 2010 | GE Profile PSS26NGS Side by Side...
I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
The Frezeer side of the Frigde is leaking cold water. We have checked the temperature and it tends to flucuate very from as high as 23 F to as low as -5 F. pls find a solution and thanks
The coils and drain are frozen. Once you thaw them and remove the ice, your problem should go away. You can do this by simply unplugging the refrigerator and waiting for it to thaw, or you can remove the inside panels and melt/chip out the ice. Make sure you get all of it, especially in the drain.
Ice tends to build up in the drain. Then, when the freezer defrosts, the water has no place to go, so it builds up until it finally overflows and leaks out on the floor under your refrigerator.
Nov 01, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Roper fridge freezer not freezing
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Veggies frozen, Ice thawed, water slow or intermittently dispens.
with out testing and or doing a full diagnostics on your unit their can be a few reasons --one is control unit ---others are slightly low on freon ---dirty condenser coil---evap frozen over with limited air flow --evap fan improper speed or frozen--damper frozen or limiting air flow or door stuck
Apr 16, 2017 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Apr 08, 2009 | GE Refrigerators
Not getting water out of dispenser in door of GE Profile Refrigerator-Think Line may be frozen
There should be a connector at the bottom of the door , if you get water to here but not through the dispenser then the line is frozen in the door . This can sometimes be cleared by connecting a steamer to the pipe and letting the steam thaw the ice blockage but this will not generally be a permanent repair . If water is not getting to the connector then it may be a frozen water tank in the fridge compartment or a faulty valve
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
