Question about Samsung Computers & Internet
Hard disk and ram
I want to upgrade my memory.If I add 160GB harddisk to my already existing 40GB,will I get 200GB or less.Also do all the drives(C:,D:,E:,F:) need formatting.Also do I need to upgrade my RAM.Currently it is 256MB.If I were to upgrade it to 1GB what exactly happens after upgrading....???????Do I get 1GB+256MB or just 1GB?
  • 56 Answers
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Posted on Nov 25, 2008
Iam having p3 proceessor,133mhz, 810e chipset, motherboard,512mb sd ram,80gb seagate harddisk. iwant to upgrade my harddisk like 160 gb or 250 gb. is it compatible with this configuration. ...
You can put a 160gb on it as is with no trouble, but should add ram to at least 1 gig to make better use of your system. Hope this helps:)
Aug 24, 2010 | Computers & Internet
I need to add space to my compaq presario desk top. i don't know how to on this computer. the model# SR5034X
If you want to increase cpu speed so you need to increase RAM memory.
You can fix it on motherbord of desktop cpu.
But if you have low space on disk storage partition so you can add space to desktop with 2 method.
(1) you can add harddisk to desktop cpu with sata or IDE .SATA harddisk is best if your motherbord support SATA.
You can add harddisk as you like for example 80 GB or 160 Gb.
(2) If you want to add RAM memory for speed reson you can purchase new RAm and fix it in memory module slot on motherbord.
There is 2 type on
RAM in currently.
DDR1 and DDR2
you can add RAM memory like 512 MB or 1GB or more.
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
Should i upgrade my power supply?
How powerfull is your powersupply? it should say on the side of the powersupply the wattage, for example 300W
if you can't find that please tell me the brand and model from the powersupply that read on it.
Jul 09, 2009 | Computers & Internet
Upgrade hard drive from 40GB to 160 or 320?
A computer can handle any amount of Hard disk. The speed and performance of the computer depends upon the way you use it. It is possible to replace the harddisk by youself. Here is a guide : http://www.fonerbooks.com/laptop_1.htm
Jun 19, 2009 | IBM ThinkPad T30 2366 Notebook
Longer Boot time after upgrading the Hard drive
first let's determine if the upgrade cause the boot speed.
Disconnect your NEW HDD and/or memory, one by one and see if you get back your fast boot. Then try with your NEW components only !
If you find it works better with new components only, then first connect your OLD HDD only and try.
If you connect both HDDs on one cable, check Jumper settings for both HDDs (Master/Slave).
Also HDD capacity and type is automatically detected by the BIOS and there is no need to put/change those settings manually.
I believe you new RAM is DDR type, too!
As written in the manual for the board, your motherboard has two pairs of memory slots, and you can use one or two modules of DDR memory, OR one or two modules of SDRAM memory, but you can NOT put BOTH DDR and SDRAM memory modules.
regards.
Apr 22, 2009 | Computers & Internet
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
My PC freezes!!
please add another 1 gb RAM to your system. then the computer does not get freezes
Jun 17, 2008 | MSI KM4M-L Motherboard
I Lost 20gb from my 160gb harddrive
Hi, you aint lost 20gb. 1mb is 1024 1gb aint 1000mb for a example i have a 40gb hard drive here, it displays 34.3gb 200gb hard drive is usually 186gb its normal dont worry. :-) all the best John
Dec 17, 2006 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Computers & Internet Logo
263 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
