Question about Vizio L32 32 in. LCD HDTV
Visio LCD, Audio Mode Flat Only
32" Vizio LCD, 1080p. In the audio setup, I find the audio mode shows only "Flat" available. When I select audio mode to attempt to change it, at the bottom of the setup screen is a note "not available". I am unable to change to any of the other modes such as Rock, Jazz, etc. as listed in the manual. This is hooked up to our cable box via the 5-wire component cables. Thank you.
  • 1 more comment
  • John Moore Nov 26, 2008
    This was solved thanks to great Vizio tech support people. When I turned off the SRS option in the audio menu, I could then change the audio modes. Thanks!
  • Anonymous Dec 13, 2008
    Yes, turning off the SRS option allows you to change the audio mode, but the result of turning off SRS is horrible sound quality. It doesn't matter that you can now change the audio mode from Flat to Rock to Pop to.....they are just different forms of terrible at least on our Vizio FHDTV (VO32L). I'm still searching for ways to increase the distinctness of voices against the background music/noise.
  • 8 Answers
SOURCE: TV turns off by itself
Most likely your power supply is damaged (blown capacitor), if it's under warranty it's a quick half hour onsite fix.
Posted on Aug 22, 2009
Testimonial: "Thanks. It hasn't happened lately. The TV is not plasma, it is LCD."
  • 8457 Answers
SOURCE: tv wont turn on. standby light is on.
Ur backlight video board is dead,must replaced to solved this problem.
Posted on Dec 12, 2009
dsacco86
  • 1077 Answers
SOURCE: just set up Vizio 32 LCD HDTV with HDMI connection - no sound
Nope, HDMI is all in one. Video and Audio.
Posted on Feb 24, 2009
  • 92 Answers
SOURCE: vizio VP50hdtv10a problems
If you still have audio and video from component and RGB which means your sustainer boards (the boards on the two sides that powers up your screen) are working. All you have to do is replace the main board. you can buy parts at Vizparts.com, Vancebaldwin.com or shopjimmy.com. Make sure that you give them the correct model and serial number so they can send you the correct part.
Posted on Jul 08, 2009
maatmartin7
  • 1213 Answers
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Posted on Aug 12, 2009
How do I get the icons off the bottom of my screen? Also how do I get the Visio 60" logo off top left of screen?
It sounds like your TV is still in 'Demo' mode. There should be a menu option on the setup screen to set it back to 'home viewing' mode. Check the video and the channel setting menus.
Jan 06, 2015 | Vizio E600i-B3 60" Full HD 1080p 120Hz...
How to reset lg motel model tv
Go up on Visio's web site. They can tell you what the steps are to get to the special setup screen on the TV.
Dec 30, 2013 | Vizio L32 32 in. LCD HDTV
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
We have a bose audio system w time warner cable on vizio 1080p 42" tv. audio went dead. bose about two years old
did you check the audio connections? do your audio rec / amp have any fuse(s)? the tv still have sound? is the jacks on the TV external / fixed .... once you have checked all this and still no sound before you call it.......... I would unplug everything and start from scratch and reconnect before I throw/buy a replacement.......... good luck
Jan 17, 2011 | Vizio L32 32 in. LCD HDTV
Not get sound out of tv
You have to select how the audio being sent, you can select the sound to be sent through the HDMI cable or through the analog AUDIO out RCA (Red and White) jacks. Please see the on screen audio setup.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 28, 2010 | Vizio L32 32 in. LCD HDTV
Visio flat screen wont work with basic cable Why?
Make absolutely sure that you've selected the right inputs and have them connected properly. Many times, even with people who know what they're doing, wires end up in the wrong places and settings can get messed up.
If it's not the wiring or setup, then it's possible that that particular input is fried or otherwise messed up.
Jun 04, 2010 | Vizio L32 32 in. LCD HDTV
Volume not working on TV
TRY CHANGEING THE MONO STERO MODE IN THE AUDIO MENU. ALSO CHECK TO SEE IF YOU ARE IN MUTE MODE AND INTERNAL SPEAKERS ARE TURNED ON.
Dec 25, 2008 | Vizio L32 32 in. LCD HDTV
Visio 32 with very little audio
If under warrenty then call vizio!
I believe its sound board but I could be wrong.
No easy fix, the part is 220$ service is 210 a used LIKE NEW 42-50 inch is 500$ shipped !
Sorry to say this but it happened to my 50 inch just before I heard a pop then it would not show a picture and had no sound.
Call them up if your tv is less then 1 yr old!
May 19, 2008 | Vizio L32 32 in. LCD HDTV
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
822 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
