Question about Riccar 8955 Upright Vacuum
Riccar 8955 sweeper won't run...where is thermal protection switc
I have a Riccar 8955 miled sweeper...I was using the sweeper and It just shut down...It appears that I have voltage to the motor. where is the thermal protection switch for the motor.
  • 2 more comments
  • thinks Feb 25, 2009
    I HAVE THE SAMEPROBLEM TRYING TO FIND THE RESET BUTTON
    MARY NOTTINGHAM
    marynott@yahoo.com
  • sjcline May 03, 2009
    My riccar 8955 wont turn on? I can't seem to locate the reset button. I know somone posted it is located on the back of the machine towward to bottom, Can't seem to find it. If this doesn't work, what else could be the problem.
  • Anonymous Mar 19, 2014
    my friend took rollerbrush off to clean wanting to be sure and reassemble correctly
  • Anonymous Mar 25, 2014
    need diagram of switch and maybe a new one
  • 25 Answers
Thermal reset is located on the back of the machine at the bottom
Posted on Mar 03, 2009
My vacuum Riccar 8955 wont turn on.
Posted on May 03, 2009
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
How do I change a belt in a Riccar vacuum
Remove the screws holding the bottom plate on. Remove bottom plate. If it's an 8955 or model with clutch to shut off the brush roll remove the rod that goes from the lever to the clutch. Look closely how the rod and brush roll are positioned in the vacuum so you can reinstall it the same way. Remove the brush roll and install the new belt and then put back together as it was.
Apr 30, 2014 | Riccar 8955 Upright Vacuum
Power for riccar 1800
Start by checking the reset button on the back. It will shut the vacuum off if their is a clog or restriction somewhere.
Dec 14, 2013 | Riccar 8955 Upright Vacuum
Riccar 8955 quick cord release
Visit your local Riccar retailer
Nov 19, 2013 | Riccar 8955 Upright Vacuum
Brush will only run for a few seconds Riccar RAD.1
This repair should be performed by a qualified Riccar repair technician.
Oct 21, 2011 | Riccar 8955 Upright Vacuum
Absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
Jul 04, 2010 | Riccar 8955 Upright Vacuum
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Where is riccar reset button>
The reset button on your model 8955 is in the back, on the left side at the bottom. It is a white button
Jan 15, 2010 | Riccar 8955 Upright Vacuum
Broke need replacement belt
You can get replacement belts for that model here:
Riccar 8955 Replacement Belts
Dec 02, 2009 | Riccar 8955 Upright Vacuum
My Riccar 8955 wont turn on.
it could be a thermal issue. take it to a local vacuum cleaner dealer.
May 03, 2009 | Riccar 8955 Upright Vacuum
Riccar 8955 Upright Vacuum Logo
744 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
