Question about Rangemaster Proffessional 110 Gas Kitchen Range
Some rings work, some don't on hob
I have a scholtes gas hob (from mains not bottle) and the rear two rings have almost no pressure and will barely light. One of them is the biggest and meant to be the most powerful. The burner rings seem clean enough. As the front two rings seem to work fine, the gas pressure would not seem to be an issue.
Should I be sticking some sort of pipe cleaner down it after taking rings off or what?
  • neat9000 Jan 17, 2009
    I have exactly the same problem - cannon camberley 10108. Rear rings have hardly any gas.
    Scholar:
    New Friend:
  • 69 Answers
Hello both of you,
my first impression will be dirt in the injectors.
I suppose this top has removable injectors. Normally you can remove them with a 7mm socket
some rings work, some don't on hob - tp021264-1-bxvwimtpanuivq3sgra5z31g-5-0.jpgAs the pressure is really very low in the grid, every single part of dirt in that little hole will block the gasstream.
When I refurbish a cooker, I always clean these thoroughly.
I wish you succes, Dik
Posted on Feb 17, 2018
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Low gas Flame
check the vent plug on the regulator.
Posted on Dec 25, 2007
SOURCE: Hob
I just had this problem, it was due to the button that the lid presses down when its lifted (the safety cut-off release). The button had siezed and the bar that presses it had bent around it so was not pressing it down. Some wd40 and gentle coaxing has it all back working agiain.
Posted on Oct 20, 2008
BarrettDenCo
  • 1772 Answers
SOURCE: gas oven lights pilot straight
Sorry to read about your problem, I hope this helps you out.
I will assume you have the gas. there is no thermocouple, your oven use electronic ignition.
you may have a bad liter or you need to clean the grills
Hotplate Top Enamel or Stainless Steel
Hot soapy water, soft cloth. Any stubborn stains remove gently with a nylon scourer.
Pan Supports, Wok Cradle (some models only)
Enamel coated Cast Iron or Stainless Steel
Cif Cream Cleaner- Faberge Lever and a nylon scourer.
Dishwasher.
Burner Caps Enamel
Cream cleaner, nylon scourer. Dishwasher
Burner Trim Rings (some models only) and Burner Head
Aluminium
Cif or other cream cleaner with a soft cloth. Be careful not to be over vigorous.
Griddle Plate (some models only)
Non-Stick Surface
Allow to cool. Wash in hot soapy water. Do not use abrasive cleaners/scourers. Dishwasher.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
I have a Scholtes gas hob on which the ignitors have suddenly ceased working on all five burners. The unit was given a good cleaning two days ago but I would have thought any dampness around the spark...
Hi John,
please call Scholtès free on 08001 58 55 00 and we'll try and get you some technical help for that. It would help us out if you had your hob's model number to hand if possible, if not we'll try and find it for you.
Hope we can help you.
Kind regards
Marc Stewart
Scholtès
Jan 10, 2011 | Microwave Ovens
LPG gas hob not working in the cold weather, the tank is full. The supply bottle and pipework start outside and the weather in the UK has been -2 degrees for the last few days.
In weather that cold, the tank pressure is low. Tank pressure will increase if tank is warm. The gas will expand to send pressure to the burners. Make sure the regulstor is working. It could be stuck closed in weather that cold. You did open the gas valve right?
Dec 23, 2009 | Belling DB3 Dual Fuel (Electric and Gas)...
Gas doesn't come through to hob
hi,mostly is the problem is in only the line,i think ur line is far in ur cooktop thats why is the gas flow is slow to out in ur cooktop try & try,open ur gas valve for about 3 min or more until the gas is out.
Sep 03, 2009 | Whirlpool GLT3014 Gas Cooktop
We are getting luke warm water and the low gas alarm is sounding even though we have a full bottle of gas. My gas hob is working fine.
even though you have a full bottle it might not be the right bottle, you have to have a min 2lb for a water heater to work, take and have the bottle checked to make sure it is the right pressure tank
Apr 19, 2009 | Water Heaters
Convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Feb 03, 2009 | Belling DB90 Electric Kitchen Range
Small flame on hob
you need to check the conecion to the gas bottle
make sure there is nothing bocing the conecion
like a twisted rubber seal ok
hopfully this is the anser yuo need
from lee
Jan 03, 2009 | Falcon 1300 Dual Fuel (Electric and Gas)...
Rangemaster Proffessional 110 Gas Kitchen Range Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
