Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Commerical reach-in problem
I have a commerical beverages reach-in problem. It seems like the temperature increases to 87 degree on saturaday.
Please help. How do i get it down to 38-41 degree?
  • jack2210 Nov 24, 2008
    What do you mean by defrosting it all?
  • 10,515 Answers
Before replacing the refrigerator's temperature controls, you should do some basic troubleshooting to make sure the problem stems from a defective control and not some other problem. The most obvious thing to check is that the refrigerator is plugged in and receiving power from the outlet. If it is running, but not cooling, it could be due to dirty condenser coils or a defective door seal. Once the coils are clean and the door seal has been checked, you can be pretty confident that the problem is the temperature controls. There are usually two control knobs, one that controls the temperature of the freezer and one that controls the refrigerator. Although they appear to be independent controls, it is important to understand that the cold air comes solely from the freezer area into the refrigerator compartment. The freezer control determines how much cold air the condenser produces while the refrigerator control adjusts the flow of cold air from the freezer to the refrigerator compartment. If there is no cold air on either side, it is probably the freezer control that is at fault. The procedure to replace the control switch is the same for the refrigerator control and for the freezer control.
window.google_render_ad(); Even though we have gone through this troubleshooting, it is still a good idea to test the control mechanism before replacing it. You will need a multitester and possibly needle-nose pliers and a screwdriver for the testing. First, unplug the refrigerator so you don't get shocked. Then, remove the temperature control's dial and/or housing. The dial will just pull straight off, but the housing may have screws holding it in place. After removing the housing, just let it hang by its wires. There should be two wires attached to the control. Label them before disconnecting so it is easier to put back together. Remove the wires by pulling on the slip-on connectors, not the wires themselves. Needle-nose pliers may be needed to remove these connectors from the terminals, especially if the refrigerator is old. Set the ohms setting on your multitester to X1 and attach one probe to each terminal. Turn the temperature control to off or to the warmest setting if there is no off position. The multitester should give you a reading of infinity if the control is on off and a reading of near infinity if there is no off position. Then turn the control to the coldest setting and retest. Now, the multitester should give you a reading of zero. If both of these tests are not passed, the control needs to be replaced. You already have the dial part of the temperature control disassembled, but there is also a temperature probe attached to it. Remove all fasteners holding on the existing probe and take note of the path of the probe. Install the new temperature probe along the same path as the original. Do not bend at a sharp angle and try to avoid bending more than necessary so the probe does not get damaged. Attach the refrigerator's wires to the new temperature, replacing the connectors if corroded. Replace the switch and any necessary housing screws you removed earlier. Plug in the refrigerator and set the temperature control to the midpoint setting. The refrigerator should start cooling down within one to two hours.
Posted on Nov 24, 2008
  • taran_2005
    taran_2005 Nov 24, 2008
    This troubleshooting also refer when u wanna decrease ur temp. :)
    Thnx.
    Master:
  • 763 Answers
Try by defrosting it all and remove what store inside. after that start it again and see if it the same problem happening.
thank you for using fixya
CHARCOIS
Water dripping on everything inside - seems to be collecting on outside of upper fan housing. Drain hose is not clogged.
You need to shut it off and get the ice to melt off the coil. With that accomplished, put a thermometer inside and don't put the temperature below 37 degrees f. Hope this helps and good luck.
Jul 05, 2014 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Aug 26, 2010 | Mitsubishi Heating & Cooling
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
