Question about Magellan GPS
Where you plug the Magellan into the RoHS P/N:730527 CT-P168SDS-NXB3.1 plug-in that goes into the cigarette lighter energy source. the little hole on the side of the Magellan has one hole for the plug to go in and it is so loose that the plug will no longer stay in and so it doesn't know that it is plugged in. It seemed like the hole had a black covering on it now it is yellow and I think maybe the black covering fell off so now the plug will not stay plugged in.?
3 Suggested Answers
  • 20 Answers
SOURCE: Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Posted on Jul 24, 2007
  • 5 Answers
SOURCE: Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Posted on Feb 08, 2010
SOURCE: My magellan maestro shuts off after 10 seconds
I had similar problem. While it was still on I pressed the recessed "reset" button and it magically fixed the problem. It retained all my prior settings and locations. Note: must press reset before unit powers off.
Posted on Mar 19, 2010
My grandpa has a 1992 Buick Park Avenue. The cigarette lighter on the dashboard does not work, but all of the other ones do. It is the hole part that is the problem because the plug works in the other...
Cigarette lighters wear out from use. On the front of the hole where the lighter goes there is a retaining ring that is threaded onto the lighter socket. Unscrew the ring and the lighter socket can be removed from the dash. Disconnect the wire from the back of the socket and replace the lighter assembly with a new one, Don't forget to plug the wire up to the back of the new one.
Jan 04, 2011 | 1992 Buick Park Avenue
Where's the little hole where I can send a power cord through the dash to the battery?
THE CIGARETTE LIGHTER HOLE. REMOVE THE CIGARETTE LIGHTER. USE A 12 VOLT POWER PLUG IN DO NOT USE 110 AC CURRENT IT WILL BURN OUT ENTIRE ELECTRICAL SYSTEM.
Jul 11, 2010 | 2004 Pontiac Grand Prix
Magellan RoadMate 3000T. When plugged into the cigarette lighter, I only get a little red light in the upper right corner. How do I turn it on? I can't understand their symbols. (it is a hand me down from...
Download the manual from here.
The LED in the upper right corner seems to be a charging indicator, so this means that the power supply via the cigarette lighter seems to be ok.
To switch it on, press and hold the power button for 3 or 10 seconds (depends on the state of the device - whether in sleep mode or off).
Mar 11, 2010 | Magellan RoadMate 3000T GPS Receiver
Jun 10, 2009 | Magellan Maestro 4250 GPS
Part of cigarette lighter connection stuck
Use a clean ice-cream stick and super glue and pull it out.
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
No power to unit, but powers on okay in house with AC power adapter
Not sure if you'll see this post, as you asked the question back in Nov, but I
thought I'd tell you what I know anyway.
I and my parents bought the same exact unit within a week of each other.
There's works, and mine does not.
I took their cradle, and hooked it to my GPS, and it came on, no problem.
I took my cradle, and hooked it to theirs, and boom, nothing.
So, with that, I was able to isolate that the problem is definitely in the cradle.
I went to the manufacturer website, registered my Magellan Roadmate 700,
and then I was able to contact customer support. I am writing to you as
I wait for their reply. Here's their website.
https://www.magellangps.com/users/registrationHelp.asp
Hope this helps!
Nov 12, 2007 | Magellan RoadMate 700 GPS Receiver
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Lost power- will not come back on
If you have a multimeter you should be able to check the out voltage on the powersupply to make sure the power cable isn't at fault. You may also try wigling the power cord a little bit to see if the unit will then get power. If so you have a faulty powercord. If there are any fuses they should usually be accessible from the outside; that's the point with them - they should be easy to change. I would put my money on the power cable. If you have access to a diferent power source try that out. If the unit works with a different power source your power source is at fault. If it still doesn't work the problem is within your unit. Check to see if any pins on the power source and/or the units power plug might be bent or dirty.
Mar 07, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
316 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Mike Cairns
Mike Cairns
Are you a Magellan GPS Expert? Answer questions, earn points and help others
