Question about Samsung U900 Soul Cellular Phone
Volume button my volume button...does it only work for the key tone because as soon as I press it, it only adjusts the KEY TONE VOLUME, not the volume for the phone, plz help
    Novelist:
  • 166 Answers
If u r referring to the in call volume....then u can increase it while ur talking on the phone only, with the same button through which u set the key tone volume...........
i hope this helps u......if it does, then pls don't forget to rate the answer....thanks
Posted on Nov 27, 2008
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER beileenc@bellsouth.net
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
Mar 13, 2008 | Lands Phones
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
What is the code to increase the volume of Samsung C3010
Hi
By volume do you mean Ring tone volume or Handset volume?
Ring tone volume adjustments.
Press menu >settings >phone profiles
Scroll the phone profile you ares using.
Press on options >edit and select call alert volume.
Scroll right or left to adjust the volume levels.
press on select and then save.
The handset volume adjust is done by pressing on the 1st side key in idle mode.
Feb 27, 2012 | Samsung Cell Phones
I just want to stop the keys making a noise when I text
Hi there!
If you're hearing a noise or a tone whenever you text then ill be advising you to check the tone settings on your phone.It might be that the KEYPAD TONE in your phone is enabled.
If you want to adjust the volume of youe keypad tone then you can just go to SETTINGS.And after that please go to TONES/TONE SETTINGS and kindly look for KEYPAD TONE.You can lower down or turn off the volume of the keypad tone on that option. If you have another kind of phone then you can try looking for small buttons on the side of the phone. You can press the "Down" button to lower the key volume. Please press it repeatedly to continue lowering the volume. Press "Up" button if you decide to turn the key tones back on.
THANKS graham569!
Apr 20, 2011 | Cell Phones
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
How do you set the key pad to silent?
Hi to adjust the volume of keypad tone you need to Adjust the volume of the key tones
In Idle mode, press [Up /Down ] to adjust the key tone
volume.
Let me know if this will solve your prob
Nov 27, 2009 | Samsung B2100 Cell Phone
Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Jun 09, 2009 | Samsung Cell Phones
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
GE28112 Dect phone
Here are the instructions and a link to the manual :
Key Tone
1. Press the caller ID-volume ( 6 or 5) button to scroll to the KEY TONE sub-menu.
2. Press mute/program button to enter the menu. SET KEY TONE 41ON 2 OFF shows in the display. The default setting is 1ON.
3. Use the touch tone pad on the handset to select 1 or 2, or use the caller ID-volume ( 6 or 5) button to scroll to your selection.
Here is a link to the manual for you :
http://telecom.hellodirect.com/eBiz/pdf/phones/GE_28111_Manual.pdf
Jan 05, 2008 | GE 28111 Cordless Phone
Samsung U900 Soul Cellular Phone Logo
137 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
