Question about GE JVM1630 Microwave Oven
Microwave problem I've got a GE (aka Camco) JVM1630 microwave. The problem I'm having the unit quit heating suddenly, and the sounds emitted are "off" from normal when run. Reading repair guides and such mention that it could be a defective power diode, voltage capacitor or the magnetron. Is there a way for a DIY'er to test these, and what to look for? I am a bit against the "when in doubt, change it out" policy and am trying to pinpoint this to fix it right. Also where can I find a parts breakdown for these units? It's hard to find the parts for pricing when I can't find the part numbers. I usually use Repairclinic.com but they dont list/carry this model.
  • 7 more comments
  • Jeremy Tucker Jan 06, 2007
    I've contacted and ordered that replacement kit from a local part supplier. It wasn't that expensive, only $114 CAD for the magnetron, stirrer and diode. Just have to wait a week for delivery :-/
  • nantel Nov 04, 2007
    No heat with GE JVM1630, but other functions are ok.
    How to tell if the problem is with thermal cutout or magnetron?
    More basic issue is finding & accessing the AC cord somewhere back there!
  • Anonymous Feb 11, 2008
    I've got a GE JVM1630 microwave. The problem I'm having the unit quit heating suddenly, the other functions are OK.
    I've got a GE (aka Camco) JVM1630 microwave. The problem I'm having the unit quit heating suddenly.
  • Jame07 Feb 13, 2008
    My JVM1630 heat function stop working, but others function are OK. Have anyone have a solution for this?
  • brannew Feb 26, 2008
    Same problem doesn't heat but everything else works.
  • PecosPete Mar 20, 2008
    no heat,every thing else works .110 fuse ok.
  • valmvac Apr 05, 2008
    Mine is a JVM1630WBC01 stopped heating, but everthing else looks like working. No error code was displayed. Any idea what to check? Fuses, transformers, magnetron, thermostats, what else?
  • Jeremy Tucker Mar 28, 2009
    After some research and dismantling the unit I found that these models had a problem where the "stirrer" would reflect some wave back to the magnetron and burn it out. GE released a statement that if the unit was under warranty they'd fix it or would give you a credit towards repair. Most appliance repair shops can get a kit that replaces the stirrer issue with a newer design and a new magnetron. Think I paid less than $200CAN for it. 30 mins later I had the new parts installed and working again.
These microwave ovens are known for bad magnetrons. Mine just failed for the second time since 2000. the first time, was after about 3 years of use. My serial number was covered under GE service bulletin RA 08-02 which covers these microwaves from Apr 1999 through July 2000. I had a GE technician come to the house and replace the part for free (including labor). My guess is that GE got a bad lot of Magnetrons from Samsung during that time (Samsung makes the magnetrons, still does). Anyhow, when the microwave broke the second time, I decided to debug it myself. I am an electrical engineer, so I felt a little comfortable doing it. You are messing with some high voltages, so you need to be very careful. Anyow, I took the top of the microwave off (didn't have any instructions). If you can't figure out how to do this without instructions you should stop right there. You probably are not qualified to work with what is inside;)
Once you get the top off, you need to discharge the big capacitor in the front. If you let the microwave sit, it should self discharge in 30 minutes. BUT YOU SHOULD NOT COUNT ON THIS. What I did was wait 30 minutes then short the capacitor with a pair of needle nose pliers. Make sure the pliers have an insulated handle. When you do this, nothing should happen if the cap is already discharged.
The magnetron is located on the right side of the microwave. You have to remove a cover (about 3 or 4 screws) to expose it. After you do this, you should disconnect the magnetron. This is done by connecting the lower of the 2 connectors on the magnetron (the top one is a heat sensor, I think). Anyhow, after you have done that, you should ohm out between the 2 pins on the magnetron, it should be less than and ohm. After that, you should ohm between each pin and the case. This should be infinity. Mine had 500 ohms on each lead, which was bad.
If yours it bad, you should order kit WB27X10489. This kit includes the magnetron, diode, and stirrer. You should replace them all. You will see the diode on connected to one lead of the big cap. By the way, mine tested out fine. Since this is a high voltage diode, you may need to put some voltage acrossed it to test it (maybe more than a normal voltmeter provides). It you take a 1M ohm resistor and put it in series across a 12V supply, you should see it clamp at 5-6V in one direction, but not the other. Anyhow, since you are replacing it anyway, you can skip this. By the way, if the diode is really bad, you should see physcial damage on it. AND, if you do have to replace it, it will cost $40-50 dollars, but come with the magnetron anyway. The stirrer is located on the top of the microwave compartment. You have to replace it from the inside/top of the microwave compartment. You have to pop a little plastic button out, and turn it. The direction of turn to remove it are on the stirrer cover itself.
After you have replaced everything, you can test it. IMPORTANT, MAKE SURE YOU HAVE PUT ALL OF THE SCREWS BACK ON THE INSIDES BECAUSE YOU NEED TO MAKE SURE YOUR CAPACITOR HAS A SOLID PATH TO GROUND. The capacitor is mounted on a little metal plate that needs to be grounded to the main chassis. As long as you have the diode screwed to this plate, and a couple of other screws between the place and the chassis, you will be fine. If you don't you are going to see some sparks as it figures out its ground for itself.
Anyhow, if it is working after you test it, wait 30 minutes, put the cover back on, and mount it back on the wall.
BTW, the magnetron is under the 10 year magnetron warranty. HOWEVER, if you have GE come out a replace it, you are going to pay a couple hundred dollars for the SERVICE CALL plus LABOR. My kit cost around $100.
Hope this helps
Posted on Mar 28, 2009
  • GE Master
  • 9,149 Answers
Word has it that many of these models have a defect which causes the microwave energy to be reflected back to the magnetron, causing damage to the magnetron, and eventually damaging the high-voltage diode too. Also, the fuse or the magnetron theral cutout / thermostat can eventually blow, too. There is a replacement magnetron and stirrer kit available. I would definitely call the GE Answer Center at 800-626-2005 about this. It's not considered a recall, but a "campaign". They may pick up part of the cost. It's not cheap. You can get parts lists and parts breakdowns from the GE parts site or the Sears parts site: http://www.geappliances.com/shop/prts/ http://www3.sears.com/
Posted on Jan 02, 2007
What causes a ge spacemaker above the range microwave to quit heating and makes a deeper pitched noise?
This louder, 60 cycle hum is usually caused by a bad magnetron. The unit will not heat when this happens. Repair cost can exceed $100.
Dec 29, 2017 | GE Spacemaker JVM1540 Microwave Oven
The oven is not heating the food. All the controls is working, but it is not heating up the items. I tried to warm up a beverge and it didn't warm up. This just happened all of a sudden. Last night it...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 11, 2010 | GE JVM1630 Microwave Oven
Have a GE model JVm1650bh05 Microwave. I put in
Check the fuse in the bottom of the oven ... near where the power cord enters.
Oct 19, 2009 | GE JVM1630 Microwave Oven
How to replace a fuze in a ge spacemaker xl microwave oven
depending the age of the unit and its usage, if not a lot its not the fuse,but I would say its more likely a H.V. Diode,H.V. Capacitor, or the magnetron tube.
Sep 20, 2009 | GE JVM1630 Microwave Oven
Microwave problem
It's more likely to be the magnetron or high-voltage recitifer diode.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once you've looked that over, here are some links:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 30, 2007 | Microwave Ovens
GE JVM1630 Microwave Oven Logo
899 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
