Question about Whirlpool Duet GHW9150P Front Load Washer
We get a F02 error relating to drain
I am not sure of the exact model #, I can't find it on the front of the washer and cannot move it myself to look at the back. The cycle runs partially through then stops and gives F02 code. I took the bottom front cover off and see what looks like the drain pump in front. It makes a cliking sound when trying to do a drain/spin cycle to empty the machine.Does this mean a bad pump, or maybe a clog or a bad control relay? Any suggestions on how to further troubleshoot this are greatly appreciated. Tony
    President:
  • 1,294 Answers
F02 is the code for long drain. Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Posted on Mar 28, 2009
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer, F02 error is flashing on board. What does error code mean?
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..Be sure you are using only 2 tablespoons of HE soap and not more than that.
Check your drain filter also and replace them if needed. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front.
Mar 11, 2011 | Kenmore Washing Machines
I have a Kenmore Elite HE3 model 44832 200 washer. Will spin sometimes, but doesn't seem to get to full speed. Often won't spin at all and gets F02 error, but it does roll during wash/rinse cycles. ...
he F02 message is a long drain error and it may mean the pump is clogged or bad. You don't provide a lot of detail about if the water is draining out or not but the first thing to check for this error is the drain pump.
The image below shows how to access the pump and remove the filter. This may be your only problem. With the access panel removed you can also make sure the pump is running. Remember to unplug the washer before removing the access panel.
Check the pump for the F02 and make sure you're using HE detergent and there's not excessive suds.
Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
F02 error and not draining correctly (pool of water left at the bottom of the washer after cycle has completed). This is on a whirlpool duet front loading washer.
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
• Check the drain hose and make sure it is not plugged or kinked.
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 01, 2011 | Whirlpool Washing Machines
F 02 is being displayed on washer. Can the washer be fixed from the front of machine.
Hi
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
Daniel
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When my washer gets done with the rinse cycle, it stops and reads F 02. Then shuts off. What do I do?
Hi
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Washer will not wash complete load. flashed f02, water not draining
F02 stands for long drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
you can press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
you might want to check..
• If the above does not correct the problem most probably you will have to replace the pump
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
• If the above does not correct the problem replace the pump
Mar 25, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
91 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
