Question about Honeywell Heating & Cooling
I have a Baxi combi boiler 105e and a Honeywell ST6100C programmer/controler, and i wish to add a Seimens wireless digital room thermostat RDH10RF/Set. the RCR10/433 unit needs to be wired to the boiler/controler above so that the thermostat switches the boiler on and of when demand for heat is called for by the room thermostat unit RDH10RF. can you please advise on how to connect the wiring or if it is possible to get a wiring diagram many thanks Paul
bigbiggs
  • 326 Answers
SOURCE: PROGRAMMABLE ROOM THERMOSTAT
I found this on a search:
"I have the full set of instructions, contact me at gjb@eggconnect.net
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
GJB"
Perhaps this can help.
Posted on Mar 16, 2008
  • 86 Answers
SOURCE: vulcan cx90 ducted heater
240 volt wiring required.
Posted on Mar 17, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Baxi Combi
You will need to isolate the boiler from the radiators because there is an auto feed valve that will continue to allow water into the system if the pressure in the boiler drops. There should be some valves off of the boiler that will allow you to do this.
Posted on Nov 07, 2008
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
SOURCE: can anyone offer advice on my baxi bahama 100
Do not use PRV to drain, use either boiler or radiator drain off.
Posted on Feb 13, 2010
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
My daughter has a Baxi Combo 105e fitted with an optional timer. I believe that the timer is possibly a Grasslin although it has no name on it. Although the clock goes round, the Central Heating doesn't...
I have a Baxi Combi 105 HE boiler that has just been fitted and it has the optional 7 day digital timer but no instructions on how to set it does anyone know where I could get them from. Many thanks
Feb 21, 2009 | Hardware & Accessories
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
When i turn heating or hot water on fuse board trips
it was a faulty heating pump. replaced, all ok now.
Jan 03, 2009 | Honeywell Electronic Programmable...
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
GJB"
Mar 15, 2008 | Computers & Internet
Heating & Cooling Logo
154 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
