Question about Samsung PCJ534RF 53" Rear Projection Television
Now i blow the outlet fuse insted of the tv fuse
I put a new h\v block iun and now when i plug in the tv it blow out the outlet fuse insted of the tv fuse. I am pluzzed on it now so i need some help now please . Thank's Chris McCoy
  • 1 more comment
  • Christopher McCoy Oct 29, 2007
    HI  this  Chris 79
     the original symptom  was the red ligth keep blinking  and  a noise like a tiked tiked  i got told it was in standbye mode and herd it was the h\v block  so i got a new ne and put in and got rid of  tick tick noise and stop the blinking red light.And now it just blow the outlet fluse as soon as plung it in and turn the set on and blow the outlet fluse.
     Thank you,
    Chris McCoy
  • Christopher McCoy Nov 01, 2007
              HI this is chris again
     and  that  part order was actaly cal this and that what i put in the set  is flyback transformer . So what wood be the raseen it  wood blow  the outlet fluse insted of blowing the  set  flus it got me  pluzzed   so if you could tell me what it could be the problem   with  this set  then i could see if that what is bad  and check  thank's
    Chris McCoy
    This is Chris again
    it is still  is just  blowing outlet fluse  insted of blowing the set  fluse   and that where i  have left off at on this set i just need to  know what could be the  problem.
    Thank's
    Chris McCoy
    Genius:
  • 1,694 Answers
Take me back to the original symptom and how you determined to change the HV block----For now,have you put the original back
and the mfr correct rated fuse(s)?? Have you double-checked
that the transformer lead is in correct flute in HV block??If not,
you likely will blow something!  Let me know....T.
Posted on Oct 22, 2007
  • 1 more comment
  • Vista Electronics Oct 29, 2007
    Original problem would have been solved by replacing the flyback transformer (IHVT),not the HV block.
    Please let me know if you need more help---if so,give exact
    details of where your repair is at now.........T.
  • Vista Electronics Nov 01, 2007
    Blows fuse when plugged in means short circuit in power supply.
    I think it is best at this point to have another tech or a shop look it over.....T.
  • Vista Electronics Nov 03, 2007
    Look for solder splash in AC power supply area.I think your tv
    problem was self-inflicted! Short must be traced and removed!
    Sorry I can't be there.........T.
Kv-27s20 fuse
if you open the back,follow the cord..theres the fuse. replace it,dont put the back on,plug it in...fuse blows right then. bad power supply.
check on our site for parts and TVs http://www.shopjimmy.com/
Sep 06, 2012 | Sony KV-27S20 27" TV
My aquabot keeps blowing fuses in or out of water
may be waterlogged. internal seal failed and its shorting out..
Aug 06, 2012 | Pool & Spa
THE MACHINE IS PLUGGED IN AND DOESN'T SHOW ANY POWER. I CHECKED THE OUTLET AND IT'S GOOD. WHAT IS THE PROBLEM?
Try checking the fuses in the back next to the plug. If they look burned or blown replace them. If the problem persists after the fact, the entire Plug Holder and Fuse Block may need to be replaced. Sometimes when the fuses blow they leave a black discharge on the contacts inside the fuse block rendering the fuse block useless and powerless.
Apr 13, 2011 | Lavazza Espresso Point Capsule Machine
Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
Oct 13, 2010 | RCA 32F531T 32" TV
My tv will not come on and sparks when i plug it in
If it sparks when plugged in that means the main fuse in the tv is not blown. If there was sorting wrong with the tv and you saw sparks the fuse should blow. If the fuse blew you will not see sparks anymore and the set will not come on. But if the fuse did not blow one of the following can be the cause.
1. A short in the line cord, check you plug and wire to make sure there are no breaks in the wire.
2. Sparking can be from a bad outlet, a plug that is not making good connection can cause sparking, try plugging in to another outlet if it still sparks check the prongs and make sure they are not blackened.
Oct 05, 2009 | RCA P52937 52" Rear Projection Television
125 v 4 amp fuse keeps blowing
if you plugged a 125 volt tv in to a 220 volt outlet you more than likely fried alof of the componets in the tv. Putting a bigger fuse in there is only going to increase the risk of it catching on fire so i would not recomend that. you might replace the power supply and cross your fingers and hope that nothing else cooked when the 220 volts hit it
Mar 14, 2009 | Televison & Video
Flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Nov 10, 2008 | Sylvania 6626LCT 26 in. LCD Television
TV TROUBLE SHOOTING PROBLEM
Have you tried another outlet in the house? If it still blows a fuse there could be an internal issue in the TV regarding grounding. Can you temporarily connect a microwave oven or similar device to that outlet to see if the fuse still blows? If it continues to blow, you can at least rule out the TV being the cause. Is the TV new? Has any recent electrical upgrades been done? Are you using an extension cord or plugging the TV's power cable into the Cable/Satellite box instead?
One important step to do regardless for all sensitive electronics is to perform a power drain by unplugging the device or removing batteries followed by holding in the products power button for 1 minute. This flushes out the capacitors and circuit board of any electricity that can prevent normal functionality.
Oct 14, 2008 | Philips 27PT543S 27" TV
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Samsung PCJ534RF 53" Rear Projection Television Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
