Question about Samsung Televison & Video
The picture is bow in and will not focus - Samsung Televison & Video
  • malloy40 Nov 24, 2008
    the model is sp55w3
  • 4,234 Answers
This is usually a convergence problem and if you can solder, you may be able to resolve this yourself. Please post the make and model so I can give you more details about the parts required as well as instructions on how to resolve this.
Thanks,
Dan
Posted on Nov 24, 2008
  • ABRsvcs Nov 24, 2008
    This set should have convergence ICs that are attached to a heatsink. These should be marked STKxxx. Since your model is a non-US model, I don't have the manual to give you more specifics. Try resoldering the pins on the ICs first (if you can solder). If that fails, replace the ICs. Please note that there are dangerous high voltages present inside the set even when unplugged.
    Dan
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture borders bow inward and blurred. Only focused in center of picture .Kinda looks 3dish
your convergence IC's have gone out. Lot of pins on these bad boys if you don't know how to solder then call a repairman, but expect a heafty bill.
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My problem is that the picture in the screen is out of focus.
I´m changed the canon to TV projection the green and is go out the convergencia above and
side right I don´t know how iter in the menu inter could you tell me how it these. thank you..
Feb 05, 2009 | RCA HD52W59 HDTV Projection Television
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
53swx10b bowed picture
Double check your work for errors such as solder bridges or incorrect resistor placement. Look carefully anywhere solder could have dripped or splattered to cause the bowing. If you entered the digital convergence mode to touch it up, you will have to re initialize the magic focus for it to function. Good luck
Mar 12, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Out of focus
Most times when the stk's are shorted the 5 amp cp fuse on the power supply opens. Check all of the cp's by the stk's and on the power supply.
Feb 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Blurred screen
unit needs convergence ic's replaced.They are stk392-150 which is an upgraded part.
Feb 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
