Question about Gateway Computers & Internet
I HAVE A MT6840 NOTEBOOK HALF THE TIME IT WON'T BOOT UP. IF I GET IT TO IT WILL FREEZE UP. FIRST IT WAS BOOTMGR I FIXED THAT THEN IT WAS PXE-E53 I DID NOT FIX THAT.NOW WINDOWS WILL BLOCK STARTUP PROGRAMS IF IT BOOTS. I HAVE USED THE RESTORE DVD'S. IT SEEMS LIKE WHEN IT WARMS UP I WON'T WORK SO I RUN A COOLER IT HELPS. SHE IS A MESS HELP!!
  • 1 more comment
  • BRADLEY680 Nov 24, 2008
    I took it apart no dust and fan works
    i took it apart and no dust and the works
    I tryed f8 went into safe mode and screen went blank. now it won't boot if i let it sit off then try maybe it will boot up. it allways will do this. it's been a long weekend. i got it free from a guy who seems to format every week. ya think it's missing like a driver or something for the motherboard
    Sergeant:
  • 177 Answers
Check the cpu cooler for dusts. If possible clean the cooler as much as you can.
Posted on Nov 24, 2008
  • spacewalker Nov 24, 2008
    Try to start windows in safe mode. You do this by pressing F8 during system startup. A menu will appear, select safe mode, press enter twice. Run the computer in safe mode and see if it freezes again
  • Gateway Master
  • 4,806 Answers
If you say that cooling helps, this sounds like a classic case of overheating, you have to clean the fan and air vents on the laptop, you can do this by buying a can of compressed air and blasting the air through the vents and fan to clear it of dust and fluff. I would also check that the system fan is working too.
hope this helps
regards
  • Lee Hodgson
    Lee Hodgson Nov 24, 2008
    check the memory also
  • Lee Hodgson
    go into the bios (F2) on boot up and set the bios to defaults, save changes, and boot again, if you still get the same result, remove the memory, clean and reseat it and try again
    keep us informed
    regards
INTEL UNDI, PXE-2.1(BUILD 082) COPYRIGHT (C) 1997-2000 INTEL CORPORATION ..RTL8111 PXE-E53: NO BOOT FILENAME RECEIVED, PXE-M0F: exiting PXE ROM NO BOOTTABLE DEVICE--INSERT BOOT DISK AND PRESS ANY KEY
Could be your HDD is faulty and has errors. Could be you have upgraded to Win10 and the system cannot find the boot sector now. Will it boot from a DVD ROM?
Jun 10, 2016 | Intel Computers & Internet
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
Missing boot manager and blue on everything
if you boot pressing F8 can you get to the repair option?
Nov 27, 2012 | Computers & Internet
Solusi untuk BOOTMGR is missing pada acer aspire one happy2 N578Q
This sounds like a hard drive failure, try your recovery disc if available, if no change! have the hardware checked for possible replacement.
Oct 26, 2012 | Computers & Internet
My cf29 Panasonic toughbook have no boot file name/ pxe-e53
This error is a network boot error.
The error message indicates that the client received at least one valid DHCP/BOOTP offer, but does not have a boot filename to download.
A fix to this problem is found on this WEB site.
http://www.bootix.com/support/problems_solutions/pxe_e53_no_boot_filename_received.html
May 18, 2012 | Panasonic Toughbook CF-29 Notebook
Once windows vista updated itself, now my computer freezes and doesn't want to even boot up...anything I can do to fix this?
Remove the ram memory one at a time and power on each time, if this fixes the problem you have a bad stick, if this fails! restore computer back to a earlier stage before this update occured.
Apr 27, 2012 | Gateway MT6840 Notebook
I have emachine T5010 in 2006. It can't boot.PXE E53 no boot file
ii think its a virus, nothing else. if its a virus u will also notice that your PC has become much slower than before, the thing for u to do is doa virus check and if u wanna be even more safe you gotta reinsatll ur OS and format ur HDD.
hope i helped, thanks, bye.
Mar 25, 2009 | E-Machines eMachines Desktop PC
Receiving PXE-E61 media test failure/PXE-M0F exiting intel PXE RO
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. This fixed my problem with the above error. Nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network.
Its a bios function not a windows function.
Jan 21, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite pro 600 won't boot up
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. If nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network. Its a bios function not a windows function. Reset your bios settings to the default.
Dec 16, 2008 | Toshiba Satellite Pro 6000 Notebook
Computers & Internet Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
