Question about Symbol MC9090 Barcode Scanner
Can't connect to web services, this error occurs when trying to connect to a program on our sql server. we have other hand held that seem to be set up the same that work. hand held that connects :- mc9090-gf0hjesa6wr hand held that does not connect :- mc9090-kkohjafa6ww wireless profile :- ip address entry is by DHCP when i look in wireless status section 3) IPv4 status it shows an ip address as been alocated. when i go to settings connetions configure network card and click on the synbol photon driver , use server assigned ip address button is highlighted but the ip address bar as "not connected" in it. we are very confused, can you help thanks Graham
  • graham1954 Nov 24, 2008
    We had already coppied the settings, and the router is set correctly.
    additionally we have a cross next to the "connectivity" symbol at the tp of the screen. When we open the connectivity it shows "SYMBOLRADIO Connected"
    on the terminals that do work it shows
    "NETWORKCARD Connected"
    Sergeant:
  • 276 Answers
It sounds like IP conflict.i would suggest uninstalling both the devices and then installing it fresh 1 by 1 and then put up the ip settings once again accurately.this should solve the conflict problem.
thanks.
Posted on Nov 24, 2008
    Scholar:
  • 135 Answers
Did you add the port number after IP address?
Please make sure you have not enabled NE2000 card and cradled.
    Genius:
  • 1,913 Answers
May be u have advanced security configure.
acess your router with this link
http://192.168.1.1 or 192.168.0.1
or if u ser acessss ip for it.
then user anme and passssword is admin
then go to advanced thenn secutiy
then u hace settings check it for mac addresds allow.
add your wireless lancard mec address in that and allow then save then restart the router.
u can know your wireless mac adress with this comand
tyoe in run cmd
then "ipconfig /all"
then u see your hardware addreses find it then add in allow.
best of ;uck dear.
  • kishor khatri
    kishor khatri Nov 28, 2008
    may me in your router sql server ip is blocked .check it.
    alsoc ehc kin sql coonection settingsin your software.
    try this command in run "ping yahoo.com -t" if u get reply from then your web service is ok.there is something rong in your softwatr sqlconnection or in your router sql ip is bloking.check also your windows firewall and antivirus firewall.
    also if u know your sql server ip.
    run ping command ti check it is reply or not.if reply is ok then connection to your sql is ok.
    then u should check in your software fro sql connection settings.
  • 19,396 Answers
Copy all network settings from the handheld that connects to the one that dows not connect,
Check the router settings, ensure that there is no security option allowing only selected IPs to the netwoer, in this case remove the security setting that filer IPs from router firewall.
  • Ginko
    Ginko Nov 24, 2008
    Also double ckeck that you are using the right network encryption key on the handheld that is not connecting.
    If the key is wrong you get an IP but you have limited connectivity (like in your case) and you cannot access the network.
    Another possible reason is that some other device on the network is getting same IP from the router, in this case you get an IP conflict and you need to change handheld mac address, this is not always possible.
    If you are using terminal software, check if "configure IP paramenters" is on, in that case you will also need to configure this option. Best thing to do is also copying this parameters from the working handheld.
  • Ginko
    Ginko Nov 24, 2008
    When that happens it is because there is limited connectivity.
    That means that for some reason the router has given a bad IP to the scanner.
    This often happens when there is an IP conflict, or the Router has a problem with the scanner MAC address, that determines the dynamic IP assigned to the device.
    Ways to proceed:
    1 turn off all devices connected to network, (computers, printers , etc.).
    Restart the router.
    Start first the reader with the network problem.
    If it still does not connect you need to check on the manual , and try the following:
    1 Assign a static IP and see if the scanner connects to the router using a static IP, the IP must be in your network range, check any IP on the network , if the IP is for example 192.168.0.8, the range is usually from : 192.168.0.1 to 192.168.0.255.
    That may not work on the WAN (Internet etc.), as many ISP do not support static IP.
    In this case put IP back to DHCP, and check on the manual if there is a way to change the MAC address on the scanner.
    If it still does not work, try the scanner on a different router, if this work replace the router.
    If the scanner does not work on a different router or network, then it looks like it has a defective wireless LAN adapter.
    G.
SQL Server error:'execution was not successful'
Owing to the small size of MS SQL database repair utility download this program can be got immediately therefore there is a chance to avoid the losing of time and trigger the analysis and Microsoft SQL Server 2005 repair database as soon as the damage occurs.
https://www.sqlserverrepairtoolbox.com/
Feb 05, 2018 | Computers & Internet
Attach a database without the corrupted log file
There might be other options out there. This is something that worked for me once but there are no guarantees that it will work at all times.
Stop SQL Server instance -> Copy MDF and LDF files to another location -> Delete original MDF and LDF files -> Start SQL Server instance again -> Create new database with exact same name and file names -> Stop SQL Server -> overwrite newly created MDF and LDF.
After this your database should be back online. If it is then go ahead and put it into EMERGANCY mode and SINGLE USER mode.
Finally go ahead and execute DBCC CHECKDB like this
DBCC CHECKDB (databaseName, REPAIR_ALLOW_DATA_LOSS) WITH NO_INFOMSGS
More information you can dig out from resources directly connected with SQL Server databases and database corruption in MS SQL Server any version...
http://itknowledgeexchange.techtarget.com/itanswers/how-to-restore-mdf-file-as-bakcup-databe/
https://www.repairtoolbox.com/sqlserverrepair.html SQL Server Repair Toolbox
May 15, 2015 | Microsoft SQL Server 2008 Enterprise Full...
How to Fix Connection Issues in Microsoft SQL Server?
RecoveryFix for MS SQL database recovery software tool is an easy-to-use, more interactive and self-descriptive software for users who are looking to repair and retrieve .mdf files. You can try this software: http://www.recoveryfix.com/sqldatabaserecovery.html or download this software: http://www.recoveryfix.com/download-sql-recovery.html
May 12, 2014 | Microsoft Database Software A5K-02817 SQL...
The software does not eve open and I get a message that Says " A network-related or instance-specific error occurred while establishing a connection to SQL Server. The Server was not found or was not...
This is a tougher one! Sometimes when you open the software too fast before thedatabase starts up, you get this. Make sure the SQL Server services are running in Windows before opening RPE
Jun 06, 2011 | Pc America Restaurant Pro Express
When booting the system the following error message appears: SQLDUMPER failed initialization
the uninstall tool vs_uninst.exe located at http://download.microsoft.com/download/0/a/a/0aacd9c1-a0c5-43ab-a428-0ee440d4472c/vs_uninst.exe.
this error usually occurs when removing certain Microsoft products, or when using the SQL server. Here is a few articles which may help you correct your issue. First, it is a forum where an individual has a similar issue, and the help offered:
http://www.sqlteam.com/forums/topic.asp?...
Next, a Microsoft Knowledge base article on the SQL sqldumper utility, and some troubleshooting techneques:
http://support.microsoft.com/kb/827690
The next page is the SQL tech support and has different errors which can be generated. Look down the list and see if you can locate your particular error and when/how it occurs:
For SQL 2000:
http://www.gridview.org/kb/SQL2000/defau...
For SQL 2005:
http://www.gridview.org/kb/SQL2005/SQLSe...
May 13, 2009 | Microsoft Windows XP Professional for PC
How to configure the sql server 2005
Enable remote connections for SQL Server 2005 Express or SQL Server 2005 Developer Edition loadTOCNode(2, 'moreinformation'); You must enable remote connections for each instance of SQL Server 2005 that you want to connect to from a remote computer. To do this, follow these steps:
  1. Click Start, point to Programs, point to Microsoft SQL Server 2005, point to Configuration Tools, and then click SQL Server Surface Area Configuration.
  2. On the SQL Server 2005 Surface Area Configuration page, click Surface Area Configuration for Services and Connections.
  3. On the Surface Area Configuration for Services and Connections page, expand Database Engine, click Remote Connections, click Local and remote connections, click the appropriate protocol to enable for your environment, and then click Apply.
    Note Click OK when you receive the following message:Changes to Connection Settings will not take effect until you restart the Database Engine service.
  4. On the Surface Area Configuration for Services and Connections page, expand Database Engine, click Service, click Stop, wait until the MSSQLSERVER service stops, and then click Start to restart the MSSQLSERVER service.
Feb 28, 2009 | Microsoft Visual Studio 2005 Professional...
Unable to create database from within VWD 2005 Express
try to complete uninstall .net framework and install it again or get the latest copy of .net framework to install 3.5 latest version already available for download
Dec 01, 2008 | Computers & Internet
SQL 401: cannot open database
SQL database Recovery Software remove errors from SQL server database and allow recover your all database of SQL Server 2012 or below versions. The software support with all over version of SQL server. Try at here:-
SQL Database Recovery
Jun 06, 2008 | Computers & Internet
Connecting of SQL Server and .net
TITLE: Connect to Server
Cannot connect to KRISHNA-02E4A78\SQLEXPRESS.
ADDITIONAL INFORMATION:
Login failed for user 'KRISHNA-02E4A78\Guest'. (Microsoft SQL Server, Error: 18456)
For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft+SQL+Server&EvtSrc=MSSQLServer&EvtID=18456&LinkId=20476
BUTTONS:
OK
Jan 10, 2008 | Microsoft SQL Server Standard Edition for...
Error while trying to login to database
You have a named instance installed with dynamic ports configured (default) named "local". In this case, the connection string would be localhost\local instead of local:1433. You could alternatively configure the service to use a fixed port and then connect using just localhost:. With dynamic ports, you would have to resolve the name of the service through SqlBrowser, which should be running
Nov 03, 2017 | Microsoft SQL Server Standard Edition for...
Symbol MC9090 Barcode Scanner Logo
140 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
