Canon Pixma MP610 Printer LCD is stating there is a paper jam, in the output slot. There is no paper jam but the error will not clear. I have followed the troubleshooting in the manual but still no prgress!
  • klcarpenter4 Mar 30, 2009
    The LCD on my Pixmar MKP610 printer shows the paper is jammed at the paper output slot, but there is no paper jam, and I cannot clear it.
  • Anonymous Mar 17, 2014
    having had a paper jam, which i've fixed, the printer refuses to print. it makes all the right noises, i've attempted all the maintenance i can think of but to no avail. help please.
  • 4,338 Answers
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4. When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in. (orange and green, starting with orange.)
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5 times Orange Destination setting See Destination setting
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 24, 2008
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
Error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Problem with Canon MP600
I had the same problem with my Canon Pixma MP610.
After stripping the printer down I found there is a lever in the path of the paper that operates a photo electric sensor. This can get stuck in the wrong position. To reset it get a sheet of A4 paper or (better) card fold back a 1 cm strip on the top edge of the paper and press it down flat. Open the rear cover and insert the sheet folded edge first and folded flap upper most over the top of the upper set of rubber rollers. Push it into the machine as far as it will go and then withdraw it. You should feel a little resistance or here a click as the lever is reset. You printer should now work.
Several hours of frustartion and foul language have brought you this fix. I hope it works for you.
Regards
Jon
Jan 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper Output Slot Error Message
When the print head temperature falls, the error is
automatically cleared.
Note:
If the print head temperature exceeds the specified limit
when the scanning unit (printer cover) is opened, the
carriage does not move to the ink tank replacement
position.
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Aug 07, 2009 | Canon PIXMA MP610 InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Jan 04, 2009 | Canon MP610 Photo All-In-One Printer
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
1,087 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
