Question about Olevia LT42HVi 42 in. LCD Television
Channel Scan I have a three month old Olevia 747i LCD Tv, everything was ok when first set up but last week lost all channels. Tried to do auto scan but wil not see anthing. Called tech support and they said needed a (Tuner Converter) to connect the incoming cable to then to the Tv. I think the porblem is more then this, can you help. Darren
  • dmccaw500 Nov 28, 2008
    Thank you for the advise, called Olevia and they want me to pack up the TV and they will take it for repair or replacement.
  • Olevia Master
  • 5,568 Answers
If you have not discarded your old conventional TV or can borrow one, I would connect it to the same signal source you are using with the Olevia. If you get reception with the substitute set, then the Olevia is defective. If you live in a metropolitan area, you could also try sticking a piece of copper wire into the input of the Olevia and selecting antenna input as the source from inside the Olevia's setup menu. If you still get no signal indications (quality is not important for this), then the Olevia is defective.
I'm disappointed to see you having trouble with this set as we own one too. Also disturbing is Olevia's current state; they are in bankruptcy so I would start complaining soon and loudly if you have satisfactorily   identified the Olevia as the problem.
Posted on Nov 28, 2008
After AIR setting and AUTO SCAN, I cannot even receive local channels 4-5 miles away. What is the problem? See below for details.
There may be a problem with the antenna connection. Channels are not being sensed during the scanning process
Dec 12, 2016 | Olevia Televison & Video
On olevia tv, channel scan will not pick up channels 3 to 13
i think the low band on your tuner has failed
Nov 16, 2014 | Olevia 332V LCD TV
How do you get a channel scan to work?
Check its input connection for any loose contact. Make sure that the external antena has been connected to the proper input socket to the TV. If all are found OK, the tuner to your set is faulty. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 08, 2014 | Olevia 227-S11 27 in. LCD TV
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
Lost channel connections
Go to the menu and then enter your choice out of them like find channels or scan/scan channels.
Apr 24, 2012 | Olevia 227-S11 27 in. LCD TV
I have a Olevia 532-H that I am unable to scan under the channel set up.
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Apr 22, 2010 | Syntax Olevia 532H 32 in. LCD HDTV
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
Auto channel search.
Check the r/c[remote control] for ' fresh ' batterys.
Do you have " air wave " reception? or cable connection?
air wave reception will scan but cable reception can't scan because the channel is 'fixed' at ch.3 or ch.4.
Nov 30, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
996 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
