Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp al1217 h4 blinking
What is problem
  • 65 Answers
H4 is a fuser heater code. This is most often a heat lamp.
Posted on Nov 24, 2008
Sharp m165 error h4-00 give solution
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
May 12, 2014 | Sharp AR-BC260 Color Copier
H and 4 is blinking on my AL1217 sharp copier
H4 - Heat roller low temperature detection
Mar 04, 2011 | Sharp AL-1217 Copier
My sharp ar 275 has a problem h4-00. what can i do ?
Hi;
H4-00 Heat roller low temperature
detection
If the heater lamp blinks normally:
Check the thermistor and its harness.
If the heater lamp does not light:
Check for heater lamp disconnection and
thermostat disconnection.
Oct 19, 2010 | Sharp AR-M205 Copier
Blinking h4 always
Hi:
Try pressing these keys in this exact order quickly. # * CLR * Then key in 14 and press start. Then turn off the copier and turn it back on. See if this clears you H4 error..
Good Luck
Andrew
Jun 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
H4 problems
Try to reset the error code by pressing : C exp1 C exp1 14 start. if the problem still occur then you should change the heater lamp
Apr 01, 2009 | Sharp AL 1631 Copier
H4-00
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and rarely the temp sensor.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Feb 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Feb 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Jan 25, 2009 | Sharp AR-M350N Copier
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
