Make sure you inserted the battery on the right side , most camera has a pictogram on the battery cover or beside the receptacle + and - to make sure the batteries are not inverted
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Installation and Setup Downloads and Drivers You don't really need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said earlier, you can use any photo cataloging program.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
The problem you describe is frequently the result of dirty/corroded
battery contacts in the camera. Try removing the batteries and
cleaning the inside contacts with a fine wire brush, steel wool, or
fine sandpaper. Remove any residue left from the cleaning, then
replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
maybe it needs new batteries..my camera does this but when it needs batteries...i'm thinking of getting a new digital camera because i have to buy batteries for it every week no matter if they're lithium or rechargable...so don't know if this is the problem but hope i could help some..
akaline batteries batteries are not powerful enough to last more than a few shots, maybe 15 or 20 depending on the lcd screen if its running all that time. use a much heavier NiMh (nickel metal hydride) they last for 50 to 100 shots. if you still have the issue then its a camera circuit issue Consider rechargeable as they save a fortune
