Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Vibrations and banging when heater is turned on
I have just bought a Haywood propane heater for my hot tub. When 1st turned on, everything was good, then after a while I noticed the hot tub had to be turned on to a faster flo rate to stop the banging and vibrations in the pipe. Now on the fast flo rate its doing it all the time. I have a 2hp pump on a small 9 jet system, so plenty of flo. Can you help please
  • nick617 Jan 09, 2009
    Thank you so much for that. Its hooked up the right way, but I dont think it can be calcium because this started soon after me plumbing it in. I think I will do what you say and check the exchanger to see if something else has blocked it.
    It is big I know, but handy. We decide to jump in and in 15mins we have hot water, much cheaper than electric.
  • 11 Answers
Wow! That heater that you have is meant for a very large swimming pool, quite a bit oversized, i bet i gets the job done quick though. I have seen before that somebody plumbed in a heater backwards, there are elevated arrows on the black manifold of the heater, make sure inlet and outlet are plumbed in correctly. Make sure you get your water tested. Because the water in your hot tub is no circulating as often (I assume) as a pool would be, the stagnate water sits inside the heat exchanger. What can happen, for instance, if you have high calcium, is the certain tubes inside the heat exchanged can get so clogged with calcium and they are completely shut and the banging noise is due to excessive heat build up inside the heat exchanger. This can ruin a heat exchanger very quickly and the heat exchanger is half the cost of the heater if you were to get a new one. You can check and see if tubes in the heat exchanger are clogged by taking the manifold off of the heat exchanger, and shining a flashlight down the different tubes. However you have to disassemble quite a bit to actually be able to do that.
Posted on Jan 08, 2009
We bought a big buddy 2 days ago and now it wont work.
Push red button down to start, maybe 3 times, then push red button down HALF way down then turn to low.
IT COULD BE YOUR PROPANE TANK, got a new one but had problems, so I left it on all night and it lit in the morning.
BUT when I got it filled the next time the man said the stem in the tank might need to take it outside and bang the tank several times, stem in the top gets stuck a lot he said.
But last is to take the tank outside and use a flat head screwdriver and turn the screw? on the side where the hose would be connected to let some out.
Feb 05, 2015 | Mr. Heater Big Buddy Heater
Haywood h250 ignition override
not advisable check for loose wires and safety circuit
Aug 03, 2014 | Hayward Pool Products Hayward H250 250k...
Keystone manuals rv
You would need to buy a propane hot water heater. Unfortunately you can not convert an electric hot water hearter to propane.
I didn't want to use either an electric or gas hot water heater so I invested in a solar hot water heater for my home. Best thing that I ever did as far as saving money. Once it is paid off then the benefits are lower utility bills.
Good luck,
Marty
Jul 15, 2014 | Water Heaters
HAYWOOD POOL HEATER
if voltage ok coming in check transformer if ok bad display or fuses
Apr 22, 2013 | Hayward H Series Pool & Spa Heater 200k...
Haywood h400 pool heater, flames coming out of flue
check gas if ok clean burners make sure it is a propane unit if a N in model number it is natural gas orfices incorrect and will overheat very dangerous
Sep 09, 2012 | Hayward H Series Pool & Spa Heater 400k...
I have a haywood H150 and checked current using a dcv meter and getting .56 volts from thermocoupler. Also checked current throughout unit and volts reading the same everywhere but pilot won't stay...
The solenoid inside the gas valve, the part that is supposed to assume the pilot light once the thermocouple is hot, is failing. You need a new gas valve. Your part number is HAXGSV0001 for natural gas or HAXGSVS0003 for propane.
John
Jun 07, 2011 | Hayward H Series Millivolt 250,000 Btu...
Haywood heater has code sf what does that mean
SF is a thermistor error. Once the heater cools down it should reset itself. If not, call a service tech.
Jul 03, 2010 | Hayward H Series Pool & Spa Heater 400k...
My Raypak versa gas heater for my hot tub will not heat the tub more then 96F, temp control is turned all the way up, just stated doing this, it was fine for a year, thanks
Water flo through the heater is too fast and the water can't get hot enough. Your by-pass valve is stuck closed and you need to open your water header and check it out. Or you may have an external by pass that need's to be opened 10-20%. This will be a valve between the inlet and outlet water pipes going to the heater. Good luck and HAPPY NEW YEAR.
Dec 24, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Want to hook it up to my hot tub
Yes, these pool heaters are designed for use with a spa. They are made to accommodate temperatures for both a pool and a spa running off of the same heater. Check the owners manual for specific instructions.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
May 23, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
454 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
