Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
How do I reset the replace lamp message
The replace lamp message and red light appear on my TV so I got a replacement lamp and put it in but the message and red light remain - how do I reset them? One note of interest I couldn't figure out how to remove the old power cords from the lamp so I didn't replace them with the new ones that came with the lamp - I still have them though.
  • Anonymous Nov 03, 2007
    BLUE GHOSTING REAR PROJECTION
  • longandshort Dec 19, 2007
    have replaced lamp but orange light will not go out. was advised by zenith only a repair person could use a special remote to reset clock. was also told that the tv would stop working in approximately 60 - to 90 days if clock was not reset.
    can the clock be reset without having to call in a repair person.
WE HAVE A ZENTIH MODEL D52WLCD THAT COMES ON AND GOES OFF. RED LIGHT FOR BULB FLASHES 8 TIMES. PLEASE HELP
Posted on Aug 29, 2009
I have a Vivitek R56, I was able to reset Total Lamp time with my remote
Posted on Sep 29, 2008
On some tvs you can access the timer by pressing the ENTER button ans the MUTE button together. You can see the accumulated hours and select ZERO to reset. This has worked on LG units
Posted on Feb 24, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Do you have a picture? If so the only way to reset this unit is to get a Zenith programmer remote. With this remote you can get into the service menu and reset the lamp timer and that will reset the unit.
Posted on Feb 10, 2008
SOURCE:
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    How to find out lamphour in PLC-XT11
    hi
    do the follwing setting on your projector to reset the lamp hour
    1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon
    2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move
    the pointer to [Yes] and then press SELECT button.
    3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
    ok
    Feb 02, 2011 | Sanyo PLC-XT11 Multimedia Projector
    REPLACED THE LAMP ..... A RED LIGHT ON THE FRONT PANEL TO THE LEFT OF THE GREEN ON LIGHT APPEARS. THE TV DOES NOT COME ON. ANY SOLUTIONS?
    make sure u put the door back for the lamp also unplug the tv fron the outlet wait 2 minutes plug back , sometimes when the lamp is replace when tv still plug needs to be reset
    Jan 03, 2011 | LG RU-44SZ61 44" Rear Projection...
    Red lamp lite on and how to reset lamp hour meter?
    turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
    Jan 29, 2010 | Panasonic 52LCX1516 52 in. Television
    Tv turns on and off 3 times before picture appears
    Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
    Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
    PT-61DLX75 replace lamp light reset
    To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
    Sep 20, 2009 | Panasonic PT-61DLX75 61" HDTV
    Tv plays for a few minutes then shuts down. the red light blinks.
    You need reset the lamp timer after
    replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
    Feb 14, 2009 | Sony KDF42E2000 42" HDTV
    Reset for new lamp
    take the lap back out and put back in
    After replacing the lamp cartridge, when you power on the TV, the message "Did you change the lamp? Press ENTER for Yes, press CANCEL for No"will appear, press ENTER to reset.
    Feb 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
    Best but repleace bulb but red light still on
    So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
    Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
    Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
    1,246 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
