Question about Honeywell Programmable Thermostat Heater
Auto fan does not turn my furnace fan on-I have to use manual on
I have an oil furnace and a Honeywell Programmable Thermostat.
When I put fan on "auto" the furnace fan does not turn on.
I have to put fan on "on" for the furnace fan to turn on.
Do I need a new thermostat or is something wrong with my furnace?
  • 34 Answers
With the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Posted on Nov 24, 2008
Fan will not cut off even in auto position. It just keeps running
If the fan will not turn off when the thermostat is turned off the thermostat is not the fault. It could be the wiring from furnace to thermostat. Disconnect the thermostat wiring from the furnace to isolate the possible problem component.
Apr 12, 2015 | Honeywell Programmable Thermostat Heater
Does thermostat have to be on Auto or On to make my heat come on?? Dont know if i have thermostat problem or Furnace problem. Furnace clix on whenever it wants to, doesnt use the schedule i have...
If the thermostat is wired correctly, and matched to the type of heat you have ie electric, heat pump, boiler, forced air, gas or oil, the heat should run in either Fan ON or AUTO. Maybe you can explain your system a little more in depth...furnace type, M#, & thermostat brand w/ M#.
Dec 12, 2013 | Honeywell Programmable Thermostat Heater
Honeywell manuals
Turn the fan in the ON position to verify you have power to the furnace. If the fan turns on, turn it back to AUTO. Pull the thermostat off the wall to get to the low voltage wiring. If you have a gas furnace, pull the red & white wires off and pinch them together. If the furnace starts, the thermostat is bad. If it doesn't start, then begin looking for flame roll out switches in the furnace burner compartment to manually reset. If the furnace inducer (combustion motor starts, & you get no flame, then it is either an ignition problem, or someone didn't pay their gas bill. :0
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
Furnace comes on and off
If fan is set to auto mode that's how it will work.Fan would only run when heat is on
Feb 18, 2018 | Heating & Cooling
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
469 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
