My 32" Beko 32WLA520HD tv keeps going all funny colours on the screen and the picture goes on and off.
Slinteriors
  • 8617 Answers
SOURCE: My television has suddenly gone
Can you post a picture of what your screen looks like along with what is the model number of your set.
Posted on Apr 09, 2008
BobbyR1234
  • 173 Answers
SOURCE: Faulty tevion lcd 32
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degradation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem.
  4. Open OSD to adjust the picture: Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed. If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
Posted on May 26, 2008
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
phil_frye
  • 295 Answers
SOURCE: my beko plasma made a pop sound then it seemed
I hope it's still under warranty as something happened to one of the power supplies. Best to either take it into a qualified service shop or see what the best prices are for a tech to come to your residence for a service call.
Blessings always,
A/V Media Tech Guy
Posted on Dec 03, 2009
SOURCE: Sanyo CE26LD81B TV going from a red to green to blue screen
same arrrgggg
Posted on Jan 10, 2010
Hi, I have a Goodmans 32" TV LD3255HD. we have a
start by checking capacitors, if the have exploded replace them
if not then may be another board probem
Aug 25, 2013 | Televison & Video
Following the beginning of digital switchover, pressing the menu button only comes up with 'picture quality' and is unable to access 'installation'.
If your TV is not in Digital it won't give you the tuning option.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
Mar 30, 2011 | Televison & Video
I keep losing th red color on my screen, what is going on
Y sus problem with your TV. You need a basic tv knowledges to repair it yourselves. Regards
Feb 26, 2011 | Sansui 32" TV
Technika LCD15DVDiD-108 no picture - sound ok
did anyone solve this please? i have the same problem and cant afford expensive repairs x
May 01, 2010 | Televison & Video
My daughter dropped my 32 inch flat on the screen and now the colour is funny
the description is useless. funny how ? off? cracked screen? blue, red, what? need some information to help you please.
frankly after a drop I would say the tv is damaged beyond repair
Jan 31, 2010 | Televison & Video
Picture goes funny
it seems that ur cable connected to ur tv is nor connected properly. trying connecting it properly or check the lens
Jul 23, 2009 | Microsoft Xbox 360 Console
Beko 32" TV won't turn on.
i have universal remote, how can i turn on dvd on beko
Feb 09, 2009 | Beko 324250WN 28" TV
Television
remote cotrol codes
Jan 06, 2008 | Beko 324250WN 28" TV
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
Sony Tv 29 Inchs, The Picture Keep Swiching off and replaced by fable shadowi pinky multi colour light
Your symptom description is a little vague. Is there sound? Is there a full screen? Assuming there is a full screen and sound I would look for bad solder joints on the boards. Particularly the CRT board but really just resolder all the connections in the set. The KV series has been plagued with more than their share of bad solder joints. Give this a try first and if this doesn't solve it give us a more detailed explanation of the problem. Good luck.
Jun 17, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
