Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
The freezer goes into a defrost mode, everything thaws then
Freezes again, what are we looking at, how can i fix it.
is it something i can do or do we need to call a tech out
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 135 Answers
Most likely the defrost timer is going bad... staying in defrost mode too long replace it (is located under cover where temp controls are on most brands)
Posted on Nov 29, 2008
All my food thawed in my freezer. Is it just defrosting or is it broken?
Most newer freezers have self defrosting. But it will not thaw out the food at all. For it to thaw completely in 1 day, the compressor did not come on at all. I would first check the fuse or circuit breaker in your home. Many different issues could cause the same result of the freezer not getting cold at all. Defective thermostat, defective compressor, refrigerant leak or loose wiring at connection points. It could possibly be stuck in the defrost mode too.
Oct 30, 2015 | Refrigerators
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Refrigerator/freezer won't stay cold.
With the defrost timer being replaced already it sounds as if the repairman is not looking at the real problem. Unit works for 2 days then things start thawing. Hint Hint... it is not defrosting. There is a heating element inside the freezer section attached underneath the internal tubing that melts the ice every 6 to 8 hours via the defrost timer depending on the defrost timer installed. To prove that it is not defrosting..... just unplug the unit and place a stand fan blowing into the freezer for about 90 minutes. I would bet that once you plug it back in it wil work for 2 days and the problem once again repeats. With 2 calls on the same unit and you still have the same problem I would be calling the service people back and demand they fully troubleshoot the defrosting element and thermostat. Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of a new part if required, they should wave any labor and service call fees.
Jan 02, 2010 | Whirlpool Refrigerators
Appears to go into an extended defrost cycle.
Sounds like your freezer has a bad defrost thermostat ( bimetal ) or bad #4 and/or #5 thermistor . This bimetal , has a high temp rating of 140 degrees , which means , when it gets to 140 behind the panel , it will cut off the defrost heater , to keep ice and food from thawing . The thermistors , tell the main control board the temps , and it decides when to restart the cooling process . I would check the thermistors by the digital controls , in the test mode , or have a technician check them for you .
Sep 12, 2009 | GE Refrigerators
Freezer coils completely frost (freeze) up--refridgerator warms
Sounds like the defrost timer or something in the defrost circuit. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 11, 2009 | Kenmore Refrigerators
Refr/freezer alternately gets too cold and thaws
My first thought: defrost timer which shuts off the compressor and turns on a heater in the freezer is sluggish.  I'd change it out.
Nov 15, 2008 | Amana Refrigerators
Freezer defrosts and unfreezes everything. A day or so later it refreezes.
most domestic freezers do not have a defrost control. .90 percent of them freeze and every few years enough ice builds up that you have to unload and manually defrost them. so what is probably happening is the stat is sticking in hte off position and not recognizing the call for cool when the temp gets up. if you catch it off and thawed try tapping the stat gently after the temp is getting way warm. if the box comes on and starts freezing again then the stat is sticking in the off cycle and needs to be replaced. usually under 75 dollars and fairly easy. two wires connect in any order.the stat itself has no in and out requirements. power in and power out when it closes. there may be a ground wire usually green and smaller connector attached to some newer stats. look close and you can see the difference. usually the voltage connections are next to each other and the ground is off to the side or end. stat is usually behind a plastic cover inside the freezer. good luck, disconnect power when you change stat of course.
Nov 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
The freezer isn't freezing and the refridgerator isn't staying cold. i unplug it to defrost it and it will work for about a week ten its the same thing all over again
guff21, you have a problem with defrost cycle.
3 things, defrost heater, bi metal, and timer. either one of the three goes bad, same problem appears.
check the defrost heater by resistance. it should have a resistance
check the timer if it is turning and tunning and transfering from cooling mode to heating mode and vice versa.
you can only check the bi-metal if its all frozen up. the bi-metal is close at freezing temperature and opens at thaw themperature.
i hope i was able to solve your problem.
Jul 08, 2008 | Refrigerators
We have a side by side maytag plus refridgerator freezer that has frost on and behind the back panel of the inside of the freezer. Everyting started to thaw. This happened to us before and we were told...
Unplugging and letting it completely thaw out is not the answer to your problem in the long run. You have a problem in the defrost system. These problems are normally cause by the following; The defrost timing device has failed. If it is a timer it can normally be located near the temperature control area. It will have a hole in the plastic cover through which you can access the clutch head screw. Turn the screw Clockwise very SLOWLY until you hear one audible click. that will put the system into the defrost mode. Wait about 25 minutes and the defrost of the freezer coil should happen. If the system does not restart and defrost happens, turn the timer again one audible click and the system will restart cooling. (Replace the timer). If the system restarts after the time period and defrost does not take place your problem is in the heater or defrost thermostat. Back wall must be removed inside the freezer to access these components.
Jun 29, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
130 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
