Protect where is the final stage of amplifier? i dont khow were to locate it.
  • kismet_basil Nov 24, 2008
    Hi, my model is SHARP Mini Component System (CD-BA1600) when I try to plug it and followed the manulas instruction to "Clear All" setting it worked but when we try to ON the unit it again turned into "PROTECT' mode on the screen. how could I fix it and have the protect remove??? please help!!!
  • 4,234 Answers
That will depend upon the make and model. Some systems use an integrated amp-pac which is a large IC. Others use discrete components (transistors etc.) Please update this with the make and model, and I should be able to provide you with more details.
Thanks,
Dan
Posted on Nov 24, 2008
  • ABRsvcs Nov 24, 2008
    Thenks for the update. The "protect" message indicates that a problem was found in the final output stage of the amp. Your model uses an an output pac for the amp. This part needs to be replaced. It is part number: VHISTK40270N1 and is available from tritrinicsinc.com for $53.09
    Keep us posted,
    Dan
Sony de-435 protect on front
Protect means a problem has been detected in the audio output stage of the amplifier and safety circuits has disabled power from the output stage to prevent further damage. Check the back of the receiver for speaker wire shorts incuding fine threads of wire. The final issue is a short in the audio output stage in the amp that will need a tech to take it to the next level.
Jul 08, 2012 | Audio Players & Recorders
Error message "Protect"
you can try to hold the stop button down for 5 seconds while the power is off to reset. If that doesn't work disconnect all the cables from the back expect the speaker cables and the power cable. then turn the unit on and reconnect the cables once the unit is on.
Jul 19, 2010 | Samsung HT-Z310T Theater System
Sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Aug 19, 2009 | Sony Audio Players & Recorders
System wont come on shows f61 on screen
This the code for protect mode. A problem was detected in the final amplification stage. Without the model number I can't give you details, but the output stages for most units that give this message are amp-pacs that cost between $65-$95.
Dan
Jul 29, 2009 | Technics Audio Players & Recorders
My technics wont turn on it comes up f 61 on display thn turns of
The F61 is an indication of "protection mode" for your unit. This means that a problem was detected in the final stages of the amplifier and the unit is shutdown to prevent further damage. Because of this indication, I suspect that you have a shelf unit. These usually have an AMP-pac or large IC as the amplifier stage. These are not cheap. Depending upon your model, the cost will range from $65 to $95 for the part alone. If you update this with the model number, I can provide the exact part number and cost.
Dan
Jun 19, 2009 | Audio Players & Recorders
Protect on dial
The protect message is an indication that a problem exists in the final amplification stage. In order to prevent damage to either the amp or connected speakers, the final stage is shutdown. Most commonly the output transistors are at fault. If you can update this with the make and model of the unit, I should be able to provide additional details and possibly the parts that are most likely defective.
Thanks,
Dan
Apr 04, 2009 | Audio Players & Recorders
My sharp Stereo is stuck in '' protect'' mode
Protect mode is not something that a reset will fix. Basically it indicates that there is a problem with the final output stage of the amplifier. Normally this indicates that the output transistors are defective. In most boomboxes, the amplifier is a single IC. If you can post the model number, I can provide you with the required part and cost.
Thanks,
Dan
Mar 25, 2009 | Sharp Audio Players & Recorders
PROTECT on start up
The protect message indicates that the output amplifier section has a problem and the unit has shutdown to prevent further damage. This usually is caused by shorted transistors in the final output stage. In your case, the output amplifier is a single replaceable amp-pac (STK402-090S). This can be purchased from tritronicsinc.com using the Sharp part number: VHISTK4029S-1 at a cost of $63.32
Dan
Jul 12, 2008 | Audio Players & Recorders
Climbing DC offset then protection mode
Hi there
Firstly, check for conductive hold down glue about the output stages. This can cause the problem you have. Or there may be a failing component somewhere in the output stage of that channel. Check for leaky transistors,diodes an capacitors. You will need to remove semiconductors to check for leakage, If you dont have alot of experience faultfinding amplifier power stages, I suggest you take it to a NAD authorised service center.
regards
Graeme
Mar 27, 2008 | NAD C370 2-Channel Amplifier
Protection of yamaha pc 2002
Protect delay is in the relay and not adjustable as to delay time.
I would not worry unless no sound then may have to replace relay.
GOOD LUCK
BIG RED
Feb 20, 2008 | Yamaha P2500S Amplifier
42 people viewed this question
 Grubhead
Grubhead
