Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Projection TV has "green" screen when should be black
I have a Sony KP-43ht20 projection TV that when turned on the screen is green. When viewing an image, the image is ok, just overall the screen is green. Any idea's?
  • 1 more comment
  • Badger14 Nov 21, 2007
    Same problem. Overall green hue to the otherwise fine picture.
  • dan pangallo Nov 27, 2007
    If I swap connectors j7202 an j7302 on "A" board and the problem changed to the Blue tube. So I suspect the green gun circuitry is overdriving the gun and causing the tv to shutdown.
    symptom is when tv is powered on the screen goes bright green and the tv shuts off then flashes red led 6 times. This repeats each time you attempt to turn on tv
  • Badger14 Nov 27, 2007
    I solved the "green screen" problem by making adjustments with the focus block. These adjustments are accessible by removing the front panels.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Call tech ..suggest screen adj.
Posted on Nov 26, 2007
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Green hue on KP-43Ht20 Sony rear projection tv
Behind the front cover you will see a little plastic box with six phillips headed dials. They only move 180 degrees. The three on the bottom control color richness and the three above them control focus. Turn all three of the bottom ones to the left while the TV is on, then gradually turn them to the right until you get the color you want. NOTE if any one of the three bottom dials are too far up the TV will shut down and will continue to turn off after about 10 seconds after start up until the offending dial is turned back a little.
May 17, 2009 | Sony KP-43HT20 43" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Can not get ride of the green "VIDEO" OR "LD" SYMBOL ON SCREEN
Solution was, I had to buy a universal remote control that had a button that read "display", The Radio Shack store was the only store I found that remote, it was only $9.95. I programed the remote to the TV code..easy and pressed display button...and the problem was solved.
I Thank everyone for viewing my problem..it was a local TV repair store in my area over the phone told me the solution,,Thanks again.
Jan 17, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
432 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
