  • ranjisilva Nov 24, 2008
    low deep bass
  • 4,234 Answers
Becasue of the way low end sound travels, if the speakers are out of phase, it will sound like the low end is significantly lower in volume that expected. Check the speaker wires to be sure that they are set up the same for both speakers. If one set has the wires backwords (+ side to - and - side to +) relative to the other, the speakers will be out of phase and cause the symptom you describe.
Let us know what you find.
Posted on Nov 24, 2008
Why are my headphones making a vibrating sound on the left side, when there is a lot of bass.
Each speaker works independently from each other. One speaker may use more low frequency tones than the other one.. Low frequency tones create a lot more noticeable vibration than higher frequency tones. You can reduce it by turning the volume down a little on the left speaker. It is possible that nuts came loose on the speaker.
Jun 01, 2014 | Beyerdynamic DT 770 PRO Professional...
Hey! I have a problem with my sony MDR-RF81 headphones....when the bass is to loud...there volume is droping...when I listen to skirllex for example...the volume is high or low...but when the bass...
Hey there, the problem with your sony is not a hardware problem, the headphones are completely fine, its the amount of bass you are putting into the headphones, there are two solutions to this, if you're using a mobile device (Apple, android etc...), go to your app store and download an equaliser e.g poweramp, with this, you can adjust the sound going through to your headphones using the built in equalizer (usually 5-10 bands, research this if you have no knowledge of equalisers), you can use this to turn down the bass frequencies in the sound, or the only other thinkable options are if you are already have an equaliser in use, turn it down, because putting all of the bars to the top makes the sound horrible, research on some suggestions for equaliser presets (another word for equalizer settings), or just turn the volume down.
the reason this happens is because bass naturally overpowers treble, and if it is too loud, the treble and mids will be significantly quieter, headphones are a menace for this, so all you have to do is tweak the sound a little (using an equaliser) to find that perfect balance between the different elements of sound.:-) :-)
Hope this helped mate :-) :-)
Jan 10, 2013 | Sony MDR-RF810 wireless headset SONY
Hello! We have some problem whith 1 chanel, when 2
BOTH turntables and the same channel on each? If it's really really low and tinny that would probably be a failure to have/use a PHONO preamp (built-in and selectable on the Mixer).
Swap the channels coming in from the mk1200 and see if it stays with the mk1200 or with the left channel of the mixer.
There IS an outside chance you have flaky connections at the cartridge.
May 06, 2011 | Vestax Pmc07pro DJ Mixer System
I had installed hamburge mp57 +two 4 chanel amplifire+one bass tube +two ovale speaker+four component speaker in all door.but engine noise is is transmiting in sound system and it is irritating.i contact...
that is not true. you can add a ground loop isolators to all the rca fittings going into the amps. plus do not run you power and remote wires on the same side as your rca and speaker wires. if rca wire are cheaper style the will pickup noise from the power and or remote leads .
Aug 27, 2009 | Blaupunkt Hamburg MP57 CD Receiver CD...
Sound problem with home theater speakers
Change both left & right TDA7275 IC
Change all the 1uf 50v capacitors related to the IC,s
Thank you very much
contact me at
thank you again
M.Fateh Almunajed
Jul 28, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Perfect ten bass amp, guitar
can you use headphones? if so do they sound normal. probably have bad filter caps. 2200uf caps big ones, go bad and lose their capacitance and cant process the low end notes, sounds like a motorboat or ******* out. speaker may have issues as well. get the caps from and careful of stored voltage on the capacitors it is deadly....... those caps are less than 2 bucks each.
Jan 21, 2009 | Ashdown Perfect 10 Bass Combo Amp Car...
JVC dual channel bridgeble Amp
Most repair shops offer a warranty. If you've recently had it repaired, return it to the shop to have them check it out. If you continue playing it as it is, more damage may occur and the additional damage isn't likely to be covered by the warranty.
Jul 01, 2008 | JVC KS-AX4750 Car Audio Amplifier
JVC dual bridgeble AMP
Have the speaker checked out and if it checks good you need to take the amp back to the repair center and have them test it better. Most repair centers have a 30 day warranty on the work they perform. Make sure they know what the problem is in detail, so they know how to check it properly. But my first thought is the speaker could be faulty. You can check the speaker yourself by switching them at the amplifier. If the same speaker sounds bad you know it is the speaker that is bad. If the sound is bad from the other speaker, then the amp is bad unless it is coming from the head unit. You can also switch the RCA input jacks after that and see if the problem changes speakers, if so, the RCA output of the head unit is bad, but that is less likely.
114 people viewed this question
