Question about HP Pavilion dv9000z Notebook
Laptop keyboard the letter cover came off how do i put it back on
    Scholar:
  • 91 Answers
What is the actual unit Part Number? I can provide an answer but HP has 4 unique models for this laptop. The PN = (something like EW680AV). Let me know. I can get you your answer. Binary Bob
Posted on Nov 24, 2008
  • Bob Morris
    Bob Morris Nov 24, 2008
    Most keyboard keys are created so that they slide and then click into place. If any part of the key is broke it will probably go back on. Take a look and let me know. Binary Bob
  • Bob Morris
    Ooops...probably will not go back on.
Letters popped out of computer keyboard
If it is a laptop, you will need to get a replacement keyboard or actual key, remove the old one and put in the new one. A key that is popped off is usually broken.
Jan 26, 2013 | Computers & Internet
Keys not working
Either the keyboard or the ribbon cable connecting the keyboard to the mainboard is damaged or not fully connected.
The most likely problem is the keyboard is defective. They are not very hard to replace. In most cases you have to remove the button cover above the keyboard and then the screws for the keyboard will be accessible. You can get a new keyboard off the Internet (EBAY or such) or direct from HP.
Aug 22, 2012 | Compaq Presario CQ62-112TU
HOW TO PUT IN THE LETTER Y IN MY KEYBOARD
If the letter Y sleeve is not damaged it should go back into place. Position the letter Y over shaft on keyboard, now line up Y sleeve with the shaft and push down until you hear a click and stop, the letter should be at the same hight as the others when in place.
Jul 08, 2012 | Gateway Computers & Internet
Sony computers keyboard is mixed in with letters and numbers eg put in i letter and 5 shows up on the sceen
Hook an external keyboard if available, if okay! keyboard on the laptop will need to be replaced.
Mar 07, 2012 | Sony Computers & Internet
Spilled some soup in my spacebar then i took it out after i put it back all letters are jumbled. i got acer aspire 1 notebook. help pls!
The keyboard is faulty and has electrical faults that is causing the jumbled letters.
To test the laptop is functioning correctly connect an USB keyboard to your laptop and check to see if the USB keyboard types correctly. If not then the laptop has a serious fault and possibly needs a new motherboard.
If the USB keyboard works OK the you need to replace the laptop's faulty keyboard.
You may be able to get a replacement keyboard from this WEB site.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Apr 25, 2011 | Computers & Internet
The letters on my keyboard have faded away...r,t,n,m are almost completely gone....o, h, u are half gone. Does this mean I have something in my blood/fingers doing this..........do you have a keyboard I...
Hello.
You can buy any keyboard at a computer store. Make sure it's a USB one and it will fit your desktop with no problem. Sometimes Asus original keyboards erase after using them for a while.
Feb 10, 2011 | ASUS Computers & Internet
All keys on laptop faulty. Cannot write one sentence without letters missing, including space-bar
Either the cable connecting the keyboard to the laptop's motherboard has come loose, or the keyboard itself is bad.
You don't give a brand or model so I can't be too specific, but it's usually not difficult to remove a laptop keyboard. On most models you need to remove the plastic hinge covers and trim strip along the top edge. Often these are one molded piece, but on some computers the hinge covers are separate pieces. Look for small screws that may hold the cover down on the back edge or possibly through from the bottom. After removing any screws, the plastic pieces snap off. Be careful not to break the strip or hold-down tabs. Just work slowly and carefully.
With the trim strip off you can see the top edge of the keyboard. On some computers there are 3 or 4 screws holding the keyboard down. Other models have screws that go through from the bottom, and these are often labeled with a K.
Once the keyboard is free, lift it carefully by the top edge and tip it toward you. You'll be able to see the cable that connects to the main board. Make sure it's firmly seated in its connector. Set the keyboard back into place (you don't need to worry about putting all the hardware back yet) and see if the trouble continues. If it's back to normal, put all the screws back in, snap the covers back on and you've fixed your laptop. Otherwise, check online (eBay's a good place) for a replacement keyboard. They are widely available now for most models, and the prices are usually reasonable. Plug the cable from the new keyboard into the motherboard connector and replaces all the other stuff.
It is possible, but not common, that the keyboard controller on the motherboard itself is bad. If that's the case, the only fix is to change the board. That's a job best left for a professional. Replacement boards are available, but can be costly, so if the board is the trouble it may be time to consider replacing the computer. But the keyboard is normally the culprit.
Good luck, and thanks for using Fixya. If this has helped you, please take a moment to give a thoughtful rating.
Oct 22, 2010 | Computers & Internet
My shift key will not work for all letters, forcing me to use caps lock by pressing it before typing the letter and immediately after typing the letter. any suggestions?
This can be either a bad keyboard or a bad system board. There's no way to tell without swapping out the keyboard. Laptop keyboards aren't hard to replace and cost about $50-60. If that does not resolve the problem, learn to live with it because a replacing the system board generally isn't worth the cost unless you have it covered under warranty.
Oct 13, 2009 | Computers & Internet
Keboard will ot tpe soe letters
Use the following link to remove keyboard. Once you remove remove the keyboard plug it back in and follow the instructions in reverse to put the keyboard back. If that doesn't work you more than likely have a bad keyboard and it needs to be replaced. If it is still under warranty call dell and they can send you a new one. If it isn't under warranty then you call dell and buy a replacement.
http://support.dell.com/support/edocs/systems/latd600/sm/keyboard.htm#1111863
Sep 13, 2009 | Dell Latitude D600 Notebook
I popped the key cover off an IBM thinkpad. How do I replace it?
The white hinge assembly likely has two parts to it that make it form a spring in the form of a letter X. You should see small catches for the feet of these two parts on the keyboard -- they will fit properly only one way. Put that back on. Then you can snap the key itself back on and it will be "springy" just like the others.
Mar 24, 2009 | IBM ThinkPad R40 2722 Notebook
HP Pavilion dv9000z Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
