Question about Dometic NDR 1292 Refrigerator
DOES NOT COOL AT ALL ON GAS OR ELECTRIC
BURNER BURNS AND GETS VERY HOT.
NO COOLING AT ALL IN FEEZER OR MAIN.
1999 MODEL DOMETIC ELITE SIDE BY SIDE
I have a NDR 1292 that does not cool on gas nor electric.
The coils do not get hot at all. Inside, the control board lights up and operates...just no cooling.
I see an answer on this page that says bad board...what board? the one inside at the top that has the settings?
Help?
Posted on Mar 22, 2011
    Problem Solver:
  • 5 Answers
This sounds like you have a block inthe cooling unit. The only way to repair this is to replace the cooling unit or replace the refer. Sorry this is not good news but this happens
Posted on Jan 29, 2009
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Dometic RM 3662 not working on gas or AC power. I've changed the heat element, I can see the flame of the burner. What's going on that the unit won't cool off. Tried gas for 5+ hours and the fridge seemed...
When running on Electric insure that the rear coils of the cooling unit are getting warm. If the refrigerator is level and the coils are warm and the refrigerator does not cool then you more then likely will require a replacement cooling unit. I have attached a small video that may help with the diagnoses. You can also give us a call toll free 1-888-782-6665 ArctiCold Refrigeration We keep it cold
Aug 27, 2013 | Dometic Refrigerators
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
I got a RM 2852 IN A 5TH WHEEL. It will work fine on gas,but 110v does not work,Any suggestions? Thanks,David
We were told that its a faulty control board on most Rm2852 units. a factory defect.
Ours did the same thing first the gas would not stay on to cool but the unti worked fine on electric...now the electric is not working...the heater gets hot and burner comes on but does not stay on..they system shuts down..and will not cool. .
Jan 29, 2011 | Dometic RM2852 Refrigerator
No cooling on 12v or gas
Hello,Depending on the age of the unit, it could have a compressor going bad on it, as the compressor gets hot the valves may not be seating correctly or may be burning out.
You may have also lost some refrigerant, but I am going to lean more to a bad compressor.
Thanks
May 30, 2010 | Dometic RM2620 Refrigerator
I have dometic modle R M 2333. It will not cool when set to gas. But is ok on AC. Burner flame is good, gas flow is good.
If the unit has a good flame and is staying lit throughout the cycle of the fridge, then you probably have a bad cooling unit. Does is cool ok on Electric? If so, then there is another problem. You may have rust build up in the flue that is not allowing the heat from the gas to work correctly. Try taking a screwdriver and small claw hammer. Remove the cover from the burner assembly and place the head of the screwdriver on the flue just above the burner. Tap the screwdriver lightly with the hammer and see if rust falls. If so, continue to do this until it stops. You then need to blow out the burner and try the fridge again.
Hope this helps,
Jeff
Jul 07, 2009 | Dometic Refrigerators
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
Neff U1420 oven gets hot then cools.
there are is an ignitor nest to the oven burner. that part gets red hot when you turn the oven on, but when starts to go bad it takes longer and longer time to open the safety valve that supplies gas to the burner. or i can turn on but it will not stay on it go es of again. the ignitor needs to be replace.
Dec 08, 2008 | Maytag MER5775Q Electric Kitchen Range
Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
Jun 13, 2008 | Dometic RM2652 Refrigerator
Dometic NDR 1292 Refrigerator Logo
347 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
