Question about Cell Phones
When either making calls or receiving calls on handset I cannot hear the caller at all. If during call I switch to activate speakerphone or if I am using bluetooth I can hear the caller.I am using a Blackberry 8120.
  • amysasser Jan 07, 2009
    Callers can hear me, but I cannot hear them unless I switch on speakerphone.
    Scholar:
  • 135 Answers
It means your voice IC is fine and working you have to change mic of the phone.
Posted on Nov 24, 2008
People can not hear the caller on Cisco 7945G
Could be a bad hook switch on the phone if you plug a different phone in does it work as it should?
May 07, 2014 | Cisco 7945G IP Phone
Cannot hear caller
To be check handset speakerphone part or electronic part for that speakerphone. There is difference handset speakerphone and speaker.
Jan 26, 2018 | Panasonic Lands Phones
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
How do I turn speaker phone
    • 1 Press the green "Phone" key on the main screen of your iPhone. This key has a silhouette of a traditional hand receiver and is located on the bottom part of the screen.
    • 2 Begin to use your speakerphone by making a call or accepting a call from other participants. You can make a call by going to your "Contacts" list or activating the keyboard and dialing a number. Incoming phone calls can be accepted by pressing the "Accept" key underneath the caller ID.
    • 3 Activate the "Speaker" function on your iPhone when you are ready to use your speakerphone. This button is located above the caller's information and allows you to switch on and off with one tap of your finger.
    • 4 Put participants on hold while you use your iPhone speakerphone. There is a "Hold" key at the bottom of the calling screen that lets you speak to people without bringing callers into the conversation.
    • 5 Access your contact information over the Internet while you use your speakerphone. You can reach the main page of your iPhone by pressing the "Home" button if you are on hold. The iPhone does not allow you to play music or use other audio options while on hold because you are still on the phone.
    • 6 Adjust the volume level before you begin a conference using your speakerphone. There are volume buttons on the side of the iPhone that provide detailed control over speaker sound levels.
    • 7 Mute the speakerphone if you must leave your office or take a break from a conversation. The "Mute" key is available on the call screen and instantly cuts off your microphone and the speaker.
    • 8 Add new contacts to your iPhone that you have called on your speakerphone. You can go back to your "Recent Calls" list or the keyboard to find numbers to add to your "Contacts" list.
Read more: How to Use the iPhone Speakerphone ' eHow.com http://www.ehow.com/how_2080582_use-iphone-speakerphone.html#ixzz1LKkzVgm3
May 03, 2011 | Apple iPhone Smartphone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
Can only hear on speakerphone
This speakerphone is a separate speaker from the handset speaker, so if you can't hear through the handset and you have ensured that the volume in your profile is set up to max, then I would have to say there is something wrong with the handset speaker.
Hope this helps,
Bill
Sep 03, 2009 | RIM BlackBerry Pearl 8100
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Callers can only hear me on speakerphone
first try to formate the set ...and problem is still there then its hardware problem ....you hv to change your phone's Mic
Jul 17, 2009 | RIM BlackBerry Pearl 8100
When makeing or receiving a call, I can hear the other person, but they cannot hear me
Ensure that the handset is plugged in to the correct spot on the bottom of the phone. Flip the phone over and look.
It should be in the handset location NOT the headset... they look the same, and the phones handset will fit in the wrong spot on the set.
Apr 27, 2009 | NorStar T7316E Telephone
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
Cell Phones Logo
418 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
