43PP925/79 won't turn on
No power to my philips. The power button on the front is on (is backlit red) as normal when in standby mode but when you go to turn on the power with remote there is a regular ticking sound from inside the tv and that lasts approximately twenty seconds. Then the red indicator power button then comes back on but is flashing intermittently but the audible ticking sound has gone. No power. The manual suggests to disconnect the wall plug, wait 60 seconds then turn back on. No good - no power to TV.
  • Rockape001 Dec 24, 2008
    My Philips rear projection set won't turn on. It seems to be stuck in standby. When you switch it on a red light cones on and thats it. Any Idea's
    Thanks
    Nick
  • 213 Answers
SOURCE: My Samsung LCD LA32R7 won't
you have a bad power supply.
Posted on Jun 11, 2008
  • 2920 Answers
SOURCE: My Philips Matchline TV won't
power supply
Posted on Sep 04, 2008
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
SD Tech
  • 14553 Answers
SOURCE: can't turn on
When you turn the MAIN off you are killing all power to the set---Some advice---If you Google the model number of this set with the word problem after it you should find what I have seen a lot in these sets: they develop bad solder connections on the power supply printed circuit board---usually the board is about 18 inches tall and 12 inches wide--A number of sites online offer to have you ship them the board and they will resolder it for you.
I have repaired about 12 of these with this problem in the last 2 years---The board has to be removed(there are quite a few plugs that need to be labeled and removed and lots of screws that secure the board in place.)
Maybe not a job for a do it yourself person but the soldering (if it is your problem) will take about 45 minutes(including removal and installing board back).
Like most modern sets this set uses lead free solder and it is soldered(the boards) in a wave or one step process---over time from heat and expansion some connections may crack or even break loose----I would look at the POWER SUPPLY board(follow the power cord as it goes right to it)
If you have any questions or need help please contact me here.
I do this here for free so if this information has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 06, 2009
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
Philips 42pfl5432d 37
Could be power supply failure
Apr 14, 2014 | Televison & Video
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
DO YOU FIX PS3s... I have tryed everything i can think of incloding different cables HD & normal,different TVs HD & normal Also holding down the power button and waiting for the beeps.But nothing...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
SAFE MODE
Have a look at this, it may help.
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Yellow light on wii
It's just the way the wii works. Hold the power button for about 5 seconds and the power button will go red and turn off instead of going yellow and going into standby mode.
www.wiihdmods.com
May 07, 2010 | Nintendo Wii Console
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Turning on TV after power outage
Not sure what you mean by "older", but I assume it's a CRT display. It takes some time for a picture tube to come up from a completely cold start. It has to get all of those electrons hot enough to start flying around, and also build up a high voltage on the screen. You don't notice it in normal operation because the power button doesn't really turn everything off, but just puts the set in standby mode. Unplugging, though, lets everything cool off completely.
If you're talking real antiques, with tube-type amplifiers, then the warmup time could be even longer. I remember as a kid watching the blank screen for a couple of minutes before a picture appeared.
What you describe sounds like normal behavior for a CRT television. Not sure what's up with that flickering red light, though.
Jun 26, 2008 | Televison & Video
Screen seems to stay on after powering off...
stand by should be when the power button turns red. There is also an off mode but it requires you to use the button on the front of the tv. Only problem with this is the remote doesn't work when the tv is in the off mode.
Jan 08, 2008 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
