Question about Vivitar ViviCam 5386 Digital Camera
Battery new batteries run out after first picture taken.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it may be necessary to clean the battery contacts of the camera. In some instances it may even need to be scraped to remove corrosion. Further in others, the battery contacts may need to be bend a little or stretched so as the ensure that it will put pressure when the batteries are connected.
The other possibility is an electronic problem internal to the camera which causes it the consume above normal power and therefore drains the battery faster. This type of problem would require the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 24, 2008
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: dsc60 battery drains quickly
First of all, you need to use alkaline batteries with you camera, if you use mercury ones they wont last long.
Posted on Mar 14, 2008
melnavz
  • 1226 Answers
SOURCE: camera won't take pictures w/new batteries
You should replace the camera with the identical battery as recommended. REfer to your manual for the browsing of the previously taken pictures.
User manual also will tell you how to replace the battery.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Apr 22, 2008
SOURCE: The camera won't stay powered on. Battery is new.
thanks, problem solved!
Posted on Jul 09, 2010
My proofcam wont take pictures, new bats red light stays on doesn't blink like other one does. Help
Have you tried swapping/exchanging batteries with those that works; maybe you should try this option first and see what happens.
Chances are your new battery is defective or that your camera needs to be serviced or repaired (motherboard defective/component failure)
Red light indicates low/drained/incompatible battery; as such no pictures will be taken/captured
Oct 12, 2017 | Televison & Video
Dsc60 battery drains quickly
Mar 14, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
My Samsung ES15 camera drains the batteries after 3-5 pictures are taken.
What batteries are you using ? Some batteries, although the correct nominal voltage for the camera, are not powerful enough for continued use. I have found the best solution is to use rechargeable NiMH batteries of at least 2100 MaH, preferably 2500 MaH.
Aug 01, 2016 | Samsung ES Cameras
What batteries do I need
Hi Angela,
There are batteries made specifically for for electronics. They usually have the Large price tag.
I use normal batteries all the time.
Are you sure they were new?
Try disengaging the Auto-Flash (It's a power hog) and see if it allows pictures to be taken.
Also, make sure there is room to record more pictures.
Best regards,
Mike
Oct 09, 2009 | General Electric A735 Digital Camera
CanonA720IS- Battery Dying Out soon
Change the battery, Or try cleaning the contacts on the battery if its a rechargeable (use pencil eraser to clean)
Dec 20, 2008 | Canon PowerShot A720 IS Digital Camera
Fuji Finepix E550. Camera working O.K. midway after 18 pictures whenever buton was pressed to take pictures the camera shuts itself off. Batteries new, able to view pictures taken but cannot now take...
Thanks for your prompt reply. The problem has been solved!!!! I put in new batteries and the camera is functioning normally.!!!!!!! It seems the batteries in the camera were old ones and not fully charged. I think its safer to put in new batteries than to use recharged ones !!!!!!
Anyway, thank you once again and have a Happy Christmas.
Gratefully,
Ken
Dec 17, 2008 | Cameras
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
Camera won't take pictures w/new batteries
PS:
Apr 22, 2008 | Polaroid i531 Digital Camera
Vivitar ViviCam 5386 Digital Camera Logo
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
