Question about Toshiba MD14F11 TV
TV will not stay on
My TV will not stay on. I'll press the power button and the tv will flash on for a split second.I've tried change outlets and unplugging for about an hour and nothing has changed. TV is just over a year old.Help
    Genius:
  • 1,074 Answers
Greetings from Belize take your set to a tech for repairs if you have not done so.your are having problems in your power supply section or your horizontal circuit.good luck.
Posted on Mar 23, 2007
Tcl model 21k77
Try turnning your tv off, unplug unit from outlet, press and hold down the power button for 30 seconds, let go of power button, if plugged into surge protector try wall outlet, if plugged into wall outlet try a different outlet, power tv on using power button on tv. Did you have a storm in you're area?
Jul 24, 2013 | Televison & Video
My tv shuts itself off!
Quite a long "description". "How can I fix it without having to check the back of the TV or going to a repairman?" (I altered the spelling etc a little there.)
Answer: Go to the internet and search for "Magic TV Repair Wand" and let me know if you find one---
Apr 28, 2012 | Emerson Televison & Video
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Jan 25, 2011 | Televison & Video
Tv won't turn on.
  • Try resetting the lamp timer
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
May 06, 2010 | Panasonic PT-60LC14 60" Rear Projection...
I have a 57" 57F500. It will not stay on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
Hope it may help you;
Regards;
VOTIT
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
No Picture, No Sound While Watching
Resetting the TV
NOTE:
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Toshiba MD14F11 TV Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
