Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Red huge is out of line and tried to adjust on the tv.The tv is a Hitachi.We just had another dish service put in. Thanks Janice
    President:
  • 4,402 Answers
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
How Do I fix the convergence on my 2001 Hitachi Projection Tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 05, 2012 | Hitachi 53UWX10B 53" Rear Projection...
I have 42'' hitachi ultravision the srceen has huge yellow tinted
If it's one of the LCD projection TV sets, that's your Light engine has failed, and no longer generates enough BLUE to balance out the Red and Green (makes Yellow) LCD panels.
That is about $600 or MORE for parts....it can get up to $1000.00 for the part alone.
Apr 02, 2009 | Hitachi Televison & Video
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Red Halo Hitachi 53FDX20B (2002) model year
You can get the replacement Convergence ICs at this website I am posting. Just order the same STK numbers that are on your Convergence ICs. They provide instalation instructions and free on line tech support with every purchase. Heres the link.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Red Halo
yes those are the convergence ICs or convergence amps. i bet you can find them by just putting the info into google.
Apr 11, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
No dishnetwork signal
OK here we go .the most common problem with dish network and directv is that any cable connections you have that are on the outside of the house are a HUGE weak point in the system.what you want to do is go outside and locate the dish once you have start following the cables until you find any of these cable connections or splices.once you have located them get a 7/16 wrench and remove the cable ..What your are looking for is corrosion in the cable connection.it will look like rust.What happens is your dish system sends 13 and 18 volts down the line to switch channels.When any water gets in these connections it will start to short the connection BUT,you will still get TV for a long while eventually this small short will start to damage the cable connection and you will lose signal all together.make sure to check all of these OUTSIDE connections.Once you find one that is bad you can go to radioshack and buy a cable prep tool that STRIPS the coax"COAX STRIPPERS" to its correct lengths.simply cut off the old connector and replace it.There is a GREAT tutorial at satellitescoop.com that shows you how to do this the right way for under 10 dollars make sure to follow the directions on that site and you should be watching TV in no time.
Dec 29, 2007 | Televison & Video
Convergence problem
I have a hdtv my red and blue are offset i need to know how to adjust properly
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
160 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
