Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
IntelLoader is missing
My computer won't start for it has a loading problem.????what should I do with this?
  • 177 Answers
I think your computer displays a message that ntldr is missing.
Use the following steps to replace these files. Insert the Windows XP bootable CD into the optical (CD or DVD) drive and restart the computer.
  1. When prompted to press any key to boot from the CD , press any key on the keyboard.
  2. Once in the Welcome to Setup screen, press the R key to repair Windows.
  3. Press the 1 key and then press Enter .
  4. Type the Administrator password at the prompt.
  5. Copy the NTLDR and NTDETECT.COM files to the root directory using the following steps:
    1. Type copy d:\i386\ntldr c:\ (assumes the optical (CD or DVD) drive is d) and then press the Enter key.
    2. Press the Y key at the Overwrite ntldr? prompt.
    3. Type d:\i386\ c:\ and then press the Enter key.
    4. Press the Y key at the Overwrite ntldr? prompt.
  6. Once both files have been successfully copied, remove the CD from the optical (CD or DVD) drive and type exit at the prompt and then press the Enter key. The computer will reboot.
Posted on Nov 24, 2008
Ntldr missing computer won,t start
Check or replace data cables to hard drive
Check in bios that drive select is set to auto.
Boot to windows dvd and repair windows start up.
Jan 22, 2014 | Abit KW7 Motherboard
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
Computer won't start hal.dll is missing
Try this link
Mar 25, 2013 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Bootmgr is missing
Bootmanager is the "program" that makes the computer able to load operating system.
If this is missing your pc won't boot up.
To solve this issue you should use the windows installation cd and install it again
Beware not to format your hard drive otherwise you will lose all your files.
Let us know if you solved your problem
Aug 21, 2011 | Acer Computers & Internet
Why wont the games load on facebook
As much I want to give you the best answer to your concern, I can't since you did not indicate what error message you are getting. But don't worry I'll still give some suggestion regarding your concern. Since you indicate that games won't load in Facebook. If that is the case, the only thing that I can see here is you are missing something. That missing piece is a Flash Player.Flash Player is software for viewing animations and movies using computer programs such as a web browser. All games in Facebook runs in Flash Player. So for you to enjoy games in Facebook what I can suggest to you is install a Flash Player in your computer. But if you already have a Flash Player in your computer and still have difficulties to load games, feel free to reply on this question for me to answer it.
I hope I answered your questions.
Thanks a lot!!
Aug 16, 2011 | Computers & Internet
Washer won't start, dl signal appears
Your unit does not see the door lock circuit, check the door to see is tabs are broken or missing. If you don't see anything broken or missing, replace the door lock. Part number 34001011
Door Lock
You can order this or go to your local part house and get this part you need.
I hope this helps
Aug 14, 2011 | Maytag MAH2400A Front Load Washer
My dell inspiron 530s is booting up but then when I try to access the control panel it freezes up and won't let me do anything. It also does not let me access any of my programs. I try to work with it...
your profile is damaged you could try logging in using another profile or restart your computerDuring the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart another option
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
hope this helps you
Aug 05, 2011 | Computers & Internet
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
Jan 31, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
