Question about Linksys -Cisco 16Port 10/100 RM Switch [ SR216 ] (107006)
LINKSYS SWITCH CAN I CONNECT LINKSYS -CISCO 16 PORT 10/100 SWITCH WITH TWICE CABLE FOR BEST RESULT OF NETWORK.
No. You will create a bridge loop. The only way to do this is if you have a smart switch capable of aggregating multiple ports into a virtual trunk.
Posted on Nov 24, 2008
Greetings i am using a cisco adsl 2 wireless modem router,what do i need to get to upgrade from a 4 port TRENDnet TE100-S55E switch to a 12 port TRENDnet patch panel,I need advice on what type of chal
Keep your 4-port and just purchase a netgear or linksys 8-port switch. This will increase your port count to 12, but you burn two ports on uplinking. If you need more ports, just get a 16-port switch then. I believe this will be the most cost effective solution.
May 15, 2014 | Cisco Catalyst 4006 Chassis ( 4006)
When I Connect Two Cisco SRW 2024 Switch with Uplink Port ,Uplink Port get Disable
Most newer switches have auto detect MDI / MDI-X ports, but try a cross-over cable since this model is end of life.
Feb 26, 2013 | Linksys Cisco SRW2024 24-port webView...
How do I connect router to computer?
Your router must be having port to connect it to computer - it may be either USB, or Ethernet port. use the cables respectively and connect it to your computer, on the same port which you use from router.
Dec 26, 2011 | Linksys By Cisco E2500 DualBand WirelessN...
Hi ya i have the problem tht i cant configure my router how to enter into it and give my password
print2.gif print email2.gif email
Title: Setting up your Linksys Router for the first time Article ID: 21463
Your Linksys Wireless-N Router comes with the Cisco Connect software which makes setting up and managing your Linksys Wireless-N Router a quick and simple experience. You'll have your Linksys Wireless-N Router up and running in no time.
NOTE: The Linksys E2100L router is only available in the U.S. For help on setting up a Valet or Valet Plus, please click here.
Some basic requirements before you begin
i. An active Internet connection.
ii. A computer with a wireless or wired Ethernet adapter, running one of the operating systems below.
- Windows XP with Service Pack 3
- Windows Vista with Service Pack 1 or better
- Windows 7
- Mac OS X Tiger 10.4.9
- Mac OS X Tiger 10.4.11
- Mac OS X Leopard 10.5.8
- Mac OS X Snow Leopard 10.6.1
Getting started
Provided that the above requirements are met, you can now begin setting up your Linksys Wireless-N Router. In this example, we'll be setting up the Linksys E3000 High Performance Wireless-N Router. The following steps will walk you through the entire process.
Step 1:
Your Linksys Wireless-N Router allows you the freedom of running setup via a wired or wireless connection. Therefore, please start by performing the instructions under the description that best matches the computer you're working with. Proceed to Step 2 once you're done.
Description A:
You are using a computer with no wireless connectivity that is normally connected with an Ethernet cable to your DSL/Cable modem.
Instructions A:
Please connect one end of the supplied Ethernet cable into the Ethernet port on your computer, and connect the other end into one of the numbered Ethernet ports at the back of your Linksys Wireless-N Router.
Description B:
You are using a laptop with a built-in wireless adapter.
Instructions B:
If you're using a laptop, please ensure that its wireless feature is switched ON, and that your laptop is positioned within 5 feet of your Linksys Wireless-N Router.
NOTE: Most laptops have a switch that turns its wireless feature ON and OFF. Refer to your laptop's documentation or online help if you're unsure where this switch is. This doesn't apply if you purchased an external wireless adapter separately.
Step 2:
On your computer, insert the supplied Setup CD that came with your Router. Setup should start automatically.
NOTE: If setup doesn't load automatically, please click here.
Step 3:
The first screen greets you with the Software End User License Agreement. Please take a moment to read through and understand the agreement. Once you're ready, go ahead and click Next.
NOTE: The Linksys Wireless-N Router model displayed on the setup screen may vary based on the Linksys Wireless-N Router model you have.
Step 4:
On the next window, please follow the on-screen instructions on how to connect your Linksys Wireless-N Router:
kb21463-002_en.png Plug one end of the power cable into your router and the other end into an electrical outlet.
NOTE: The Linksys E3000 features a power switch, located at the back-end of the unit, next to the power port. Please make sure that this switch is ON. Other Router models may not have this feature.
kb21463-004_en.png Plug the Internet cable into the yellow port in the back of your router labeled "Internet". Plug the other end into the modem.
QUICK TIP: Click Show me how for an illustrated guide on how to complete the above instructions.
After completing the above steps, click Next to continue.
Step 5:
Setup will now perform a series of tests to determine the optimum configurations for your network. You may notice your computer connecting and disconnecting to a wireless network several times. This is normal. Your wireless network is simply being secured.
NOTE: The setup process automatically generates a unique and secure Wireless Network Name (SSID) for your convenience.
kb21463-006_en.png Step 6:
The next part of the setup automatically detects your Internet connection type. If you are using a DSL connection, you may be requested to enter your account details. If this is the case, simply enter your Account name and Password in the allocated fields. Otherwise, you may skip ahead to Step 7.
NOTE: If you don't know your Account name and Password, your Internet Service Provider (ISP) will be able to provide these details.
QUICK TIP: Click Examples to see what your Account name should look like.
kb21463-007_en.png NOTE: Cable Internet users will not see the above screen.
Step 7:
Sit back and wait a moment as setup finalizes your Linksys Wireless-N Router settings, and re-establishes your Internet connection.
kb21463-008_en.png Step 8:
Once your Internet connection is up and running, a confirmation window similar to the screenshot below will appear on your screen. Your Linksys Wireless-N Router is now secure and connected to the Internet. This concludes the setup process. Click OK to continue.
Step 9:
You will now be taken to the main Cisco Connect window which lets you manage and further personalize your network settings. If you would like to learn more about the available features in Cisco Connect, please click here. Otherwise, you may click on the Close button to exit Cisco Connect, and begin surfing the Internet right away.
NOTE: To launch Cisco Connect again at later time, on a Windows computer, go to Start>All Programs>Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For more help on this, please click here.
kb21463-010_en.png NOTE: Cisco Connect is automatically installed each time you use the Setup CD or Easy Setup Key to setup or connect to your Linksys Wireless-N Router.
© 2010 Cisco Systems, Inc. All rights reserved.
Nov 04, 2010 | Linksys Wireless-G WRTP54G Router
Linksys will not connect correctly to my laptop
Try a new setup.
Step 4:
Step 5:
Step 7:
Step 9:
Nov 02, 2010 | Linksys Wireless-G WRT54G Router
How to configure my router to ADSL2 modem router
- Windows 7
Getting started
Step 1:
Description A:
Instructions A:
Description B:
Instructions B:
Step 2:
Step 3:
Step 4:
Step 5:
Step 7:
Step 9:
Oct 16, 2010 | Linksys Wireless-G WRT54G Router
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
Linksys EZXS16W Issue
Hi There, first of all you need to connect from your modem or router's port a link. Use a cat5 ethernet cable from the modem to the switch or if you also use a router from a port in back to the switch. Then when you plug in other computers it will see the internet connection. Good Luck...
Oct 28, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
I have a cisco router linksys. I connect internet cable to it in ethernet port. Neither by wire not by wireless I can connect my laptop. The connection comes as only local
If you can plug the cable that you have ran into your router into your computer directly and it works, then you can plug the router back in. Then connect the computer to the router via cable and unplug the router for about 15 seconds and plug it back in. If you connect the computer by cable directly and it doesn't work, then try unplugging your router for about 15 seconds and then plugging it in. I have found many networking items that need to be reset whenever a network cable is plugged in when the device is powered on.
Jun 08, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
Not all ports seem to work
Try to use different ethenet cable. If you get same problem problem then its a bad port.
Oct 08, 2008 | Linksys -Cisco 16Port 10/100 RM Switch [...
Linksys -Cisco 16Port 10/100 RM Switch [ SR216 ] (107006) Logo
183 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
