Question about HP Compaq d530 SFF PC Desktop
I want to remove the mounting plate attached to the motherboard
I need to replace bulging capacitor.pls send me step by step guide. thanks
  • 37 Answers
I have to say i strongly reccommend u take it to an expert.. it could be so dangerous for u to take on this job.. even i wldnt try it and i no wot im doing lol. A capacitor a passive electrical component that can store energy in the electric field between a pair of conductors (called plates). ur pc cud b turned off for a year but these conductors store th energy indefinately..so even after being off for a year if u were to place ur finger btween these conductors u wud get such a boot off it ud wonder whr all ur extremities went to and ud have a diff hairdo lol.. unless ur confident (and preferably qualified lol) i wld strongly urge u not to.. sooo not worth it..and unless qualified any do-it-yourself u take on is ur own responsibility. and unless u understand th next line..jus dont bother lol
i want to remove the mounting plate attached to th - d1c4d302bb2b37577a8a80c28767e1c1.png
have i convinced ya.?? lol xx.
Posted on Nov 24, 2008
Inner screen is crack on a kurio
Kurio 7 Screen Replacement
Written By: Eric Rice (and 6 other contributors)
Comments: 2 Favorites: 5 Completions: 12
Main guide photo
Difficulty
Moderate
Steps
12
Time Required
30 - 45 minutes
Sections
Back Panel
4 steps
Kurio 7 Motherboard Removal Guide
5 steps
Screen
3 steps
Flags
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
This is an easier part to replace than many others on the Kurio 7. Most require soldering, but this one does not. However, you must exercise extreme care when taking the device apart so that none of the soldered connections are broken. In the event that they are broken, look to our other guides for repair tips.
Tools
Buy these tools
Phillips #00 Screwdriver
$6.99
Buy
iFixit Opening Tools
$1.99
Buy
Parts
Kurio 7 Replacement Screen
Available for sale on Amazon
Buy
Step 1 Back Panel
Begin by removing the rubber cover from the Kurio 7.
Add a comment
Post comment
Step 2
Remove the four 30 mm Phillips #00 screws from the outer case.
Add a comment
Post comment
Step 3
Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
Be careful not to break off the tabs that hold the front cover and the back cover together.
Add a comment
Post comment
Step 4
Once all of the tabs are removed, the back cover should come off easily.
Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Add a comment
Post comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Buy Now
Step 5 Kurio 7 Motherboard Removal Guide
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
Carefully set the battery aside.
Add a comment
Post comment
Step 6
Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
Place the screws aside in a container separate from the other size screws. You will need these later.
Add a comment
Post comment
Step 7
Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
Pull the ribbon out of the mount.
Add a comment
Post comment
Step 8
There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
To remove the ribbon from the mount, follow the same steps in Step 3.
Add a comment
Post comment
Step 9
Pull back the ribbons and put the battery near the bottom of the Kurio.
The motherboard is now removed so that other components can be worked on.
Add a comment
Post comment
Step 10 Screen
Flip motherboard down near base of device.
Be careful not to pull out any wires when moving the motherboard.
Add a comment
Post comment
Step 11
This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
Once you have created some space between the screen and the cover, slide the opening tool under the screen.
Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
Be careful not to pull too ******* the motherboard while doing this, as there are still many wires attached to the body of the device.
Add a comment
Post comment
Step 12
You have successfully removed the screen!
Pull the screen out from the casing.
Jan 07, 2018 | Tablets & eReaders
I needed to replace climate control unit on1997 Grand Am GT. Concerned with how to remove the cluster face panel w/o breaking it.
Let me know if this helps out.
Heater & Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the screws securing the cluster trim plate to the instrument panel.
  3. Tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash. Remove the trim plate.
  4. Remove the screws attaching the accessory trim center plate to the dash.
  5. Tilt the top of accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel. Remove the plate.
  6. Remove the screws attaching the control assembly to the dash.
  7. Remove the control assembly from the dash.
  8. Disconnect the control assembly electrical connectors.
  9. Remove the control assembly.
To install:
  1. Install the control assembly.
  2. Connect the control assembly electrical connectors.
  3. Install the control assembly attaching screws.
  4. Push the mounting clips into place and roll the top of the accessory trim plate upward into position.
  5. Install the screws attaching the accessory trim plate to the dash.
  6. Push the mounting clips into place and roll the top of the cluster trim plate upward into position.
  7. Install the screws attaching the cluster trim plate to the instrument panel.
  8. Connect the negative battery cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 40; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 23, 2011 | Pontiac Grand Am Cars & Trucks
Pls why sametime mortherboard whet off how will i solve the problem
Those computers have a problem with bulging capacitors on the motherboards. Look at the little cylindrical things on the motherboard. If the tops on any of them have bulged, you need a new motherboard.
Apr 20, 2010 | Dell OptiPlex GX260 PC Desktop
My motherboard was no power.
Try replacing the SMPS and check if it still not working then practically see the capacitors which have bulged this could mean you need to replace them as they might have failed. Kindly send me your valuable feedback
Jan 16, 2010 | EliteGroup ECS K8M800-M2(2.0)...
After replacing the bulged capacitors(MSI-7507) the computer doesnot bootup?Is there any other problem in the board?
Sometimes Electrolytic Capacitors, do not show visual signs of failure. The Electrolytic Paste didn't develop gas inside, it just dried up. (No bulging case, no rubber seal blown out, no paste oozing out)
The 'Caps' located around the processor, are Voltage Regulators for the processor. These 'Caps' are critical.
Processors must have 'clean', steady, supply. Their tolerance range is very small.
IF even One of these 'Caps' are bad, the processor will not start up, or keep running.
(BIOS senses the in-discrepancy, and will not turn the processor on, or will quickly turn it off)
The replacement capacitors must have the same Microfarads, and voltage.
Not doubting your soldering/electronic skills for one minute but,
1.If you have a cold solder joint, or burnt the trace on the motherboard
2.Did not follow anti-static guidelines,
3.Did not remove all hardware components from the motherboard before soldering,
(i.e, Processor, Ram Memory, and so forth)
4.Accidentally forgot to attach the 4-pin ATX power cable, from PSU to Motherboard
5.Do not have all Ram memory Modules fully seated
6.Do not have the 24-pin ATX Main power cable plugged in all the way.
7.Harddrive/s is/are, do not have the interface cable plugged in, or not fully seated.
The computer will not boot up either. Sometimes in our haste we become too zealous, and accidentally overlook some of the simple things.
As for any inherent issues dealing with this MSI motherboard, none to my knowledge
Oct 03, 2009 | Intel Motherboard
SUSPECT DAMAGED CAPACITORS
Bulged capacitors are blown, that is the reason why the motherboard do not start.
Sometimes replacing capacitor may fix the problem, but due to the inexpensiveness of motheboard, and to the chance that more component may had been damaged by the fault, when this happen you usually replace the motherboard, rather then repairing at component level.
Aug 09, 2009 | EliteGroup PM800M2 Motherboard
Need guidance to install a web cleaner for canon copier ir5000
4.2.1 Removing the Fixing Web
1) Slide out the fixing/feeding unit.
.2) Remove the 1screw , and detach the
fixing assembly upper cover (yellow cover)
3) Remove the two screws used to hold
the fixing web assembly in place, and
open the fixing web upper assembly
While pushing the web feed roller
and the web take-up roller toward
the rear, remove the web Mount the fixing web by reversing the steps used to remove it.
4) Wind the web around the web take up
roller two or three times while
making sure that the arm guide plate
will be outside the take-up roller (when
attaching to the front).
At this time, check to make sure that the
area of contact with the roller is impregnated with oil.
Jun 02, 2009 | Canon imageRUNNER 5000 Copier
MY SCREEN ON MY LCM-17v8 MONITOR TURNS COMPLETELY WHITE AFTER FIVE MINUTES!
Generic problem for all Monitors Benq lcd Displays only white var g_tryMail = 0; MessageRate.ThreadID = 421124; MessageRate.ProductID = 689784; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse shared by 2 users posted by MatrixNet on Mar 02, 2008
I have a BenQ FP791 17 in LCD. I was working until one day I turned it on and it now only displays an all white screen. I plugged it in to another computer, same problem. I can add it as a second monitor to windows but all it displays is white. Windows finds it and the mouse can move over to it but I do not see anything. I am handy with a soldering iron, but not nessisarily diagnosing electronic problems.
Comment posted on Oct 26, 2008I ended up replacing the bulging capacitors on the board inside, and now it works. Thanks for all the comments and help.
Feb 20, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Hi - benimur
Pls check:
  • if CPU heatsink fan turning;
  • if heatsink is flat on CPU and tight;
  • if PSU exhaust fan turning;
  • if Video Card heatsink fan turning;
  • with a voltmeter, pls check consistency of the yellow and red wires (+12 and +5);
  • pls inspect capacitors near the CPU, none should be blistered, bulging are leaking;
  • remove the HDD connection and observe it will restart, if no, then probably a driver/software issue.
Aug 18, 2008 | Intel Motherboard
SyncMaster 214T Flicker Repair
We have a step by step repair guide posted on our web site at: www.ccl-la.com. The guide shows how to dis-assembly the monitor and what needs to be replaced.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 07, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
HP Compaq d530 SFF PC Desktop Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
