Question about Samsung SCH-i730 Pocket PC
Freezing Samsung i730
Lately my Samsung i730 is presenting with 2 problems. 1. It is FREEZING and I have to use the stylus to restart it. It will freeze at anytime doing anything. 2. The batteries are getting sucked dry and it really freezes when the battery is low. I have two batteries the regular one and an extended battery. Both will be full when I start the day, but then be 50% by the middle of the day. HELP!
Re: Freezing Samsung i730
I have had the freezing problem 3 times. Everytime it was a software conflict. The first times were after I had upgraded my computer and the "helpful" computer people had upgraded my Outlook from 2000 to 2003. Things were great for a while, but then I got screens to insert my disc for Office 2003 and I got the black screen. This only resolved after I purchased Office 2003 from e-bay. Then, I had trouble with my security program, trendmicro. I forgot the password and couldn't delete it, etc, etc. Only after it expired and I removed the program could I get around it. So, what you have to do is a hard reset: hold down the on/off switch on the side and at the same time, do a soft reset with the stylus. This re-sets the device back to factory default. You then should have a working phone. If resetting the phone doesn't help, you may need a replacement phone. If it works, then you have to re-establish a connection with the pc and restart loading your programs one by one. You could backup the device after each successful load, so that at any time the freezing starts, you could go back to a previous successful load The second problem suggests that something is running all the time behind the black screen of death--like a software conflict. If this doesn't resolve with a hard reset, you probably need a new phone. Hope this helps. Obviously I've been where you are SEVERAL times, and know the frustration. I'm now elated that my phone works, my itunes is working again(another disaster related to computer upgrade) and everything electronic in my life is humming along well for the first time in WEEKS. Good luck Georgia Newman
Posted on Jan 14, 2007
0 characters
3 Points
My samsung i730 mits has a lock code on it and I have tried to do a hard reset, but it goes right back to the password screen with a count down at the top of the screen, I assuming it is seconds, but is my...
Try this code but back up you files before doing this.*#2767*3855,and wait until the phone restart completely.If still asking a code put or type this 00000000.
Mar 13, 2010 | Samsung SCH-i730 Pocket PC
Samsung sch-i730 touchscreen problem
use buttons to go to start,settings,system,screen then click align screen
Jan 17, 2009 | Samsung SCH-i730 Pocket PC
Touch screen defective,
same problem here. Certain areas on the bottom of the screen dont work at all. Other areas I have to tap the stylus 20 times or more an hopefuly it catches. I wont be buying another phone from samsung.
Jul 25, 2008 | Samsung SCH-i730 Pocket PC
Samsung E250 white screen
Hello if you want you could get it repaired or type *#8999234*348# it restarts inside the phone so u will lose all your data on phone like games music pictures videos and phone book but it will fix it or pay $80 dollars for new screen if you want more help my email is and i fix phones all time i fix them my self pay $80 or come to me ill fix it for $25 plus warranty if it stuffs again. The white on screen means it forgot what was happening and just froze white and restarting by the code, Not just turning it of by holding red button, full restart by typing the code in the call screen any more worries about mobiles send me a email.
Mar 25, 2008 | Samsung SGH-U600
I730 phone module fatal Error
I've had my i730 for years. Never had that problem. Virus? Or maybe just too much info in it. I used mine on a picture web site and that about wiped it out. But the reset took care of that.
Sep 25, 2007 | Samsung SCH-i730 Pocket PC
Samsung i730
Ok not turning on is kind of vauge.  This is what I would recomend trying.  First off pull the battery and put it back in it should automatically boot in about 5 seconds.  If this does not work use the power button slider on the side of the phone.  If that does not work use your stylus in the reset button found on the bottom of the phone on the left hand side this should restart the phone after you remove the stylus.  If that dosent work you can do the master reset and try that.  If that dosent work I would say that you are out of luck with your phone.
Sep 13, 2007 | Samsung SCH-i730 Pocket PC
Samsung i730 phone how to do a hard reset
so you lost the stylus i would suggest finding a replacement one because that is kind of important however there are many blue tooth devices that require a stylus and you can get pen stylus combo sets.  To do a master reset on the i730 you are going to hold down the power button slider place the stylus in the rest hole on the bottom of the phone then hold for five to ten seconds and release the power slider and then remove the stylus from the reset button.  This should work and the phone is very particular about order and timing.  You might have to try it several different times but this should work for you=)
Sep 02, 2007 | Samsung SCH-i730 Pocket PC
Samsung SCH-i730 Pocket PC Logo
129 people viewed this question
Top Samsung PDAs Experts
Ronald Thompson
Charlotte Byrams
Charlotte Byrams
Are you a Samsung PDA Expert? Answer questions, earn points and help others
