Question about LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium
Cannot remove water filter from LG 26 cu ft side-by-side in the d
Cannot remove water filter.
When rotated from lock to unlock position will not release.
Upward and downward pressure in unlock position won't release.
Has been in place for approx 12 months.
Have inserted and removed several water filter units since 2004.
  • 1 more comment
  • Jerry Beacom
    Jerry Beacom Dec 08, 2013
    My filter would not budge until my son figured out that the top shelf in the refrigerator was too high. I took the top shelf out and it allowed the water filter to drop enough so it just came right out!
  • Donna Seeman
    Donna Seeman Dec 06, 2017
    Yes! This is exactly the problem. I tugged and tugged. It wasn't until I took the shelf out, the filter cover dropped further down, and so did the filter. Popped out easily!
  • Sunder Rajan
    Sunder Rajan Feb 03, 2018
    Thank you. This worked for me
Here's the only thing that worked for me in getting the water filter out of my LG refrigerator after trying for three weeks, pulling hard by hand, using high-grip gloves, and trying an oil filter wrench. You have to break or lessen the suction created by the water in the filter. Do this by first turning the filter to the Removal position (in my case, a quarter-turn to the left). Then grip the filter tight and rock it back and forth slowly as far toward the back and front of the refrigerator as possible, while keeping a bit of downward pressure on the filter. This lets the two O-Rings "walk" their way down the insert tube. After only a few pushes and pulls - voila! -- it lets go and will drop right out.
Posted on May 20, 2012
    New Friend:
For me the top shelf was too high and would not let the filter drop far enough to pull out. I had to remove the top shelf to remove the filter.
Posted on Dec 08, 2013
  • 3 more comments
  • Jerry Beacom
  • JNAMI
    JNAMI Sep 29, 2014
    YES THAT"S the problem. The filter door NEEDS to open ALL the way to be able to remove the water filter because the shelf IS preventing the filter from releasing. I now WROTE inside my filter door to -1) remove top shelf 1st before removing filter as a reminder next time.
  • Ian Springer
    Ian Springer Mar 07, 2015
    Thank you - I probably would have broken my filter housing soon had I not seen this!
  • Tyler Stephens
    Tyler Stephens Jul 26, 2016
    Thanks Jerry ... I am a handy guy but could not get mine loose and gave up ... It was exactly what you said , I took out the shelf which was in the very top holes and it came right out ... It let it go down the little extra it needed to dis-connect ... If I hadn't read your comment I would of probably have had to call a service tech ...
  • Sunder Rajan
    Thank you. This saved me a lot of anguish.
Turn water off to relieve the presher wiggle the filter and pull down on it. it will not bake you need to use force to pull it down and out of the refrigerator
Posted on Jan 18, 2009
    New Friend:
Here the only solution that worked for me!! http://www.youtube.com/watch?v=ovBPNzYelNg
Posted on Apr 04, 2013
    New Friend:
Had to remove top shelf. This is a design flaw:(
Posted on Nov 05, 2017
    New Friend:
We tried all the above tips after many previous attempts and finally was able to pull the filter down and out in our LG fridge. Thanks to you all.
Posted on Dec 09, 2015
I can't seem to remove filter the cap came off but I can't seem to get filter out
With the cap off the filer was not turned far enough for it to clear the locks. Grab the filter with a pair of pliers and turn it to the unlock position then pull it out.
Aug 14, 2014 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
We changed the water filter, now we have a blast of water then a VERY slow trickle this has never happened before wehave changed the filter at least once before.
Hi and welcome to FixYa, I am Kelly. If this just started after a filter change then the problem is right at the filter. Here is what I suspect has happened. The filter is supposed to depress a flapper in the housing where the filter locks into. If by chance you got a filter that has the lock tabs in a slightly different positon or the tip is shorter than the previous one it may not be going into the housing far enough to open the flapper.
Remove the filter you currently have installed again. Then when you reinstall it
push very HARD in before rotating it to the locked postion. This should ensure the flapper opens and stays open. If you have the same symptom after doing this the tip of the filter may very well be too short to open the flapper.
To be honest I have seen this symptom often where the user has purchased the incorrect replacement filter and they experience the exact symptom you described. There are several different lock in type cartridges and the locking ends vary in length and the position of the locking tabs so if the wrong filter gets installed the end result is as you described.
If you pass your model number I will respond with the correct filter for your unit.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Icemaker
Assuming everything is hooked up, and the water valve is in the on position, you might just try replacing the water filter. It filters the water that is used for the ice as well as the drinking water. If the filter is clogged you will get no ice and the flow of drinking water will be greatly reduced.
Sep 14, 2009 | Admiral 26 cu. ft. Side-By-Side...
I have a Maytag side by side refrigerator and lost my manual. How do I remove the inside water filter cartridge, which rotates either direction but does not easily come off?
first shut of trhe water and then let the pressure off of the line by openoing up the water dispenser . then turn it counter clockwose and then it sjhould come right off
Dec 24, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
disconect water line and make sure you have water pressure.
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Logo
4,305 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
