Question about Intel Desktop Board D845WN Motherboard
How to update desktop Board D845WN to run vista
Ive been given an assignment at school.
The task is to submit a report outlining your response to a request to update a Desktop Board D845WN to run Vista. report all details eg. a copy of the mainboaurd specification.
Im scared im going to fail.I I cant get my head around this one.! I also have to give a quote on the price fo the update. can anyone help
  • belindablue1 Nov 24, 2008
    Yeah I just worked that out about half an hour ago Thanks heaps....Blue
  • 488 Answers
Hi! details are here and here..as far as vista goes its not compatible with vista..all the best!hope it helps!do get back for any more help/clarification..
Posted on Nov 24, 2008
  • Lalit Varadpande
    Lalit Varadpande Nov 24, 2008
    thank you!all the best for the assignment!
Intel desktop board d845wn front panel powder led, power switch, hdd led, reset switch connection problem.
Hi, here you can read info and download drivers
for your mainboard:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845wn
The pin layout look like this:
Connect: 1 and 3, 2 and 4, 5 and 7,6 and 8.
The 9 number is not in use.
Its also printed in on the mainboard with very small letters.
Sep 20, 2011 | Intel Desktop Board D845WN Motherboard
Hi sir; I have a pc with intel d845wn mother board.It is not supporting usb 2.0.What can i do
You may be able to upgrade the BIOS firmware so it can support USB 2.
You can download the motherboardBIOS upgrade and device drivers from Intel WEB site. Select your
model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers
thatmatches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Apr 29, 2011 | Intel Desktop Board D845WN Motherboard
I haven't driver
here : http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845WN
Mar 05, 2011 | Intel Desktop Board D845WN Motherboard
D845WN mobo--USB 2.0 doesn't work i can activate the usb 2.0 .In the intel page says waws in the bios in advanced-usb configuration but in my bios doesnt appear
Solution to your problem is at the following URL:
http://support.intel.com/support/motherboards/desktop/sb/cs-009024.htm
If this does not work, then update your BIOS. You can download it at:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=664&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Updating the BIOS might help resolve the problem.
May 27, 2009 | Intel Desktop Board D845WN Motherboard
FRONT PANEL PIN ASSIGNMENT
Here is the original manual in .pdf that will help you. Have a great day.
ftp://download.intel.com/support/motherboards/desktop/D845hv/hvwn_English.pdf
Feb 14, 2009 | Intel Desktop Board D845WN Motherboard
133hz sdram problem
Please check this Intel link that shows specifications for memory that can be used in the Intel D845WN motherboard.
http://www.intel.com/support/motherboards/desktop/d845wn/sb/cs-008941.htm#1
When upgrading or increasing memory. The DIMM's should be the same. The Intel D845WN board requires the memory to run at 3.3volt. If the memory you are adding is within the Intel spec's, than switch the two Dimm's. Insert only the new DIMM & check if the system hangs. If it does than it is possible the new memory it either not compatable or is defective. For more information about the D845WN board download the manual for you're Intel board. http://support.intel.com/support/motherboards/desktop/d845wn/sb/cs-008937.htm
Luck!
Mike
May 19, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Intel Desktop Board D845WN Motherboard Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
